John_Mc
I have an original British Motor Corporation radio that came with my TR6 (though not installed) as well as an aftermarket MetroSound Radio/Cassette player that was installed and semi-functioning when I got the car, but has been out for a long time. I thought I'd check and see if either still works and maybe install one. I hooked up the radios to my 12V charger (on 2 amp slow charge) and hooked up alligator clips for speaker wires to the speaker. On both radios all I heard was a low monitone hum that didn't change as I scrolled through the stations. I did not have any antenna connected. Now, I know very little about electronics. I can use a voltmeter, but as far as amps and ohms and faradays and giga-hertz and neutrinos I'm pretty clueless. So, first of all, should what i did have worked if the radios were still working? And if not, what should I change? Thanks for any and all advice, suggestions, and comments.
