Nelson
I just fired Little Mo up after replacing the blown head gasket. It actually runs very well. My initial few laps on my driveway circle had it sputtering when I accelerated hard and then it died. When I flipped my fuel pump selector switch to the Facet pump it ran perfectly. Initially I was using a pump from Moss that they call a replacement for the solid state SU pump that died earlier this year. I have the two pumps connected in series with a switch to select which one gets the 12 volts. Now I need to check the timing as I had removed the distributor in tracking down the cause of my intermittent engine death. It will be great being able to drive again. Looking forward to a Healey gathering in Columbus, OH later this month.
