Rebuilding Lotus 907 Engine
I've recently acquired a Jensen-Healey with a very smokey Lotus 907 engine in it. Seems to run fine but for that problem (and a bad miss when cold, due to oil fouled plugs). The exhaust pipe is full of soot and hard acceleration leaves a cloud worthy of James Bond making a getaway....
I also got a later engine from an Elite. I plan on stripping it down, rebuilding it over the next couple months and then give the J-H a big Christmas present. I'd planned on not doing the engine til next Fall, but it smokes so, so badly that I don't think it will pass inspection due next April and be allowed on the roads.
The Jensen-Healey Preservation Society has what I think is a pretty good overview of rebuilding these engines and some of the go-faster improvements, but...
What books or printed sources are there for rebuilding these engines?
What are the best or useful public or free sites with useful information?
TIA
E
Esprit2
There are no independently published workshop manuals for Jensen-Healey or Lotus... like Haynes' or Chilton's. There are unauthorized copies and scans floating around on eBay and such, but they're just copies and nothing new.
The Jensen-Healey's 907 evolved over the years and there were significant changes. Like rope seals Vs lip seals and a completely different way of mounting the oil pick-up in the block.
The Jensen-Healey manual covers those early Jensen-only versions, but the Lotus manuals don't mention them. On the other hand, all the 907 manuals seemed to be works in progress with additional information all the time. So a later Lotus manual would be a good thing to have just because they're more complete. However, Lotus manuals are pretty pricey and only the Engine and Technical Data sections would apply, so not very economical. Maybe it's time to get friendly with a Lotus owner near you.
The 1983-87 Esprit Turbo & S3 Service Notes (aka, workshop manual) had a Technical Data Section TDA that back filled a lot of data about the natrually aspirated 907 & 912 engines that never appeared in earlier manuals. As such, it's a helpful supplement for any 907 owner. Contact me offline and I can help you put your hands on one.
The JHPS is a great resource for J-H owners and you should get to know them. They do have some sources for parts that are interesting and a good pool of knowledge. However, I don't agree with everything that they preach. Listen there, but keep an open mind and get an alternate view point before drawing your own conclusions. Especially when it comes to non-standard performance tuning.
Try subscribing to some of the Lotus mailing lists on YahooGroups. Especially the early naturally aspirated Esprit Group. Just go there and do a search for S1S2S3Owners. Then browse the "Files" section and hangout for a while. You will find a lot of technical knowledge there that will apply directly to your 907 (you may have to ask).
Are you thinking of a straight OEM rebuild, or do you intend to hotrod it a bit? If the latter, then the best thing you can do to a 2.0 liter 907 is stroke it to 2.2 liters. That doesn't sound like much, but it makes a huge difference in torque. And the 907 is such a torqueless wonder that any help is appreciated.
Regards,
Tim
Platinum
The "Shop Manual" I have here is likely an early one, has VERY little on body/chassis, not much more with regard to the engine. Compared with what we're used to (ie: Bentley, factory Lotus manuals, etc.) as "shop Manuals" it is a disappointment.
Tim's right: Suss out the Lotus guys' sites/forums and hope there's a good knowledge base and some well heeled owners.
Platinum
It was an "in-house" designed Lotus block. Alloy 'n liner'd. For the Esprit, and used in the J-H... Before the Esprit was released.
Didn't they also use them in the wedge shaped front engine cars (eclat, elite) also?
Platinum
Yup. It was a "leaner". Bit lower profile for stuffin' it into an engine bay with a lower height.
JamesWilson
[ QUOTE ]
[/ QUOTE ]
Still stripping the spare engine down...
What it looks like.
From the front, with the pan flat:
From the top, showing the wet liners:
and the head:
More "goodies" to follow in due course... I hope.
Still trying to figure out the distributor.... /ubbthreads/images/graemlins/confused.gif
Platinum
Front two holes look a lot cleaner than the back two, James.
Head's a three piece affair. I've a 907 here as a planter. /ubbthreads/images/graemlins/devilgrin.gif
I did save the cam troughs and bump-sticks.
I didn't realize they leaned "that much", but under a turbo, I know they are legendary. I also know that if you overtorque the head bolts, it will skew the head, and help the headgasket to blow (and cause other problems).
Platinum
Alloy blocks with wet liners are "tetchy" about that kinda thing... and you HAVE one of those. When you start it on a COLD morning, don't even THINK about throttle app until the temp gauge comes off'n th' peg. You'll be buyin' head gaskets by the six-pack.
...just a word in yer ear.
JamesWilson
[ QUOTE ]
[/ QUOTE ]
Is this a common problem? This is my spare that I'm stripping down. The one in it badly fouls the rear plug. That's 2 out of 2.... /ubbthreads/images/graemlins/frown.gif
Accumulating bits, will post photos in due course.
Excel (Toyota type 58) 5 speed tranny and bell housing, should help a lot with motorways and driving at speed (.78 top vs 1:1) and I should be getting the lighter steel Esprit flywheel to go with it....
I've acquired a 2.2 crank & bearings (the bearings cost as much as the crank!) and will be getting high compression pistons and a later model head....
Am I having fun! I think....
Platinum
Only problem I see is the DPO had the carbs set wrong.
The reason I have a 4-pot planter is I bought it for the five speed gearbox attached to it. For the +2... "project pending".
Platinum
Some eye-candy for ya:
An Esprit conversion, but it'd work on yours too! /ubbthreads/images/graemlins/wink.gif
healeyneil
Now thats a clean engine. Im about to put a 907 with eclat gearbox into an AH Sprite project. Anyone out there ever done this? It looks like it should fit OK. Next few weeks will tell
Platinum
HOLY COW Neil!!! What are ya plannin' to use as a diff? And for tyres?!?!
A friend shoe-horned a Buick (Rover) V-8 into a Frogeye back in the mid-70's: shortened the axle tubes from a GM car (details are hazy... it was a LOOONG time ago). It would literally SPIN itself around like a top if you weren't careful. Really a handful to drive. A 907 would be a ~bit~ more tractable but still a BEAST. Keep us up on this li'l project, will ya?!
healeyneil
Jensen Healey rear axle is planned (same stud pattern and not much wider) A friend here until recently had a rover V8 with a narrowed jag back end in his frogeye. Hes just gone back to 1275 power funny enough
Platinum
More valuable as a 1275 than a BUICK, I suspect.
Certainly easier to drive. /ubbthreads/images/graemlins/grin.gif
JamesWilson Rebuilding Lotus 907 - Parts acquired, Advice? Lotus 4
S TR2/3/3A Rebuilding a cylinder head Triumph 10
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
Xte Rev counter rebuilding ... Austin Healey 2
