"it works for me"
why
"it works for me"
"it works for me" was used in the discussion of teflon tape or not in brake fittings. I read that just after a poster saying "being shot down" which may have referred to my comment on carb #3 fire about the simple task of checking float bowl, gas line leak, and jet assembly as being a first check before doing serious engine innards analysis as suggested by the poster.
Short of a true statistical analysis of controlled tests, many of these controversies including what type of brake fluid to use much less flushing every 2 years are simply our reporting on our experiences. 4 UK oldie cars for over 20 years and have never changed brake fluid, after 15 years at earliest occassional slight leak noticed by dampness on tire, and fluid added to bleed that specific rebuild. 4daily drivers kept about7 yrs, 80,000 miles never a drop of brake fluid needed ('06 Sti still rockhard Brembo feel).
I have always taken various comments as folks reporting on their own best guesses and own experiences with no intention to "shoot people down." Some posts have been godsend of fix for something I have spent years trying to sort out, and others of no value, but always taken with posters best of intentions. Sorry, I never intended to shoot anyone down.
HEALEYJAG
Re: "it works for me"
Had that happen to me once on a reccomendation that I had made...got ripped for my comments....I just blew it off ....it was a "how dare you question my authority".....kinda shocked me at the time....still think my comment was the right approach to the guy's problem.
Personnally I like varied opinions from which I can choose...speaking from experience usually its the simplest solution.
Pete
davidb
Just got back from being away and was catching up on all the good wisdom from the BCF and noticed this topic.
I too was put on the rack for a seemingly innocent comment on paint several years ago. It hurts, because you are trying to be helpful and some bozo who fails to understand simple language decides to get into a p***ing contest.
As I've stated in the past this is a great forum supported by an impressive group of intelligent and passionate individuals from across the globe. How many websites can boast that achievement?... and hats off to Basil and the tech moderators who keep the ball rolling.
I agree with the the two comments already posted. I've learned a lot from the guys who take the time and have the patience to provide their experiences, photos and expertise, sometimes over and over again.
Negative personal comments add nothing to the discussion, and can act as a deterrent to those whose opinions might otherwise be helpful.
Apologies for the sermon.
Cheers
DB
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
Mickey Richaud Viva Restomod on Goblin Works Garage Other British Cars 2
HealeyPassion Works Rally Side Vents Austin Healey 24
J TR2/3/3A Speedometer Works Removal Triumph 10
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
dougie Lowest Mile Works Sebring Sprite for Sale Austin Healey 5
magman Maps of the Warwick works and the Cape of Good Hope Pub Austin Healey 9
T Works Healey colour spec? Austin Healey 4
David Townsend 3000 Works Rally Prints Austin Healey 2
S Works Healey paint Austin Healey 2
S Works Grill Austin Healey 3
S Question: Works Vent, how to fit Austin Healey 0
turtle Works Rally Car up for Auction Video Austin Healey 5
dougie Works Rally Car XJB 871 Austin Healey 7
W TR6 TR6 Horn only works when key is off Triumph 27
B Works Boot Rack [ For boot read trunk] Austin Healey 5
J Starter works fine but car catches after you let off on the starter Austin Healey 14
PeterK General TR Triumph Works in Detail book Triumph 0
Jeepster NEC classic car show UK - 3 works Healey 3000s on AH club stand Austin Healey 20
M TR6 TR6 how the engine works Triumph 7
PAUL161 General MG Will The MG Roadster Return? It's Supposidly In The Works! MG 7
A TR4/4A My next restoration with a little help from "Fantom Works" Triumph 2
Jim_Gruber And so Bugsy II Restoration starts/Shell Number/ RS Bulkhead/Evaporust works Spridgets 1
apbos Works hardtop. The value of or cars is climbing! Spridgets 11
dougie 767 KNX Works Big Healey Up for Auction Austin Healey 4
dougie !966 Sebring /LeMans "Works" Sprite Going to Auction Austin Healey 2
V Engine Stand XK150 What works? Jaguar 5
JPSmit Electronic Rust Inhibitors: works? - or snake oil? Restoration & Tools 8
KVH Fuel Gauge Works Triumph 4
7 Its driving season and everything works Triumph 5
G Only voltage gauge works Triumph 10
RickB My speedometer finally works! Spridgets 7
Lon_S What hub puller tool works well for the front hub? Spridgets 2
HealeyPassion Works rally tribute car... sorta done Austin Healey 29
AUSMHLY Works rally side vents...more than meets the eye Austin Healey 18
Gundy found out gas gauge works Spridgets 12
A Mice - what works for you? Austin Healey 31
HealeyPassion Works side vents project paper Austin Healey 13
T works overdrive switch Austin Healey 4
T It works....with one caveat. Dang. Triumph 77
Tinkerman The O/D WORKS, it really does!!!!!! Triumph 19
H Factory works competition Healey Austin Healey 8
A horn works!! horn doesn't work !!! Triumph 29
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
G My Brake MC Reservoir Fix Works! Triumph 14
PeterK Well, the parking brake works ... Triumph 12
Bret Bret's EFI Skunk Works hits a few speed bumps. MG 9
J Got it running-again-Works great Spridgets 1
Bret Bret's Skunk Works Teaser MG 10
