What hub puller tool works well for the front hub?
Lon_S
I'm replacing the front disc rotors on my '65 Midget and so need to remove the front hubs. Haynes recommends using a hub extractor or puller. What sort might work? Is that the only option (albeit it's probably the easiest).
Thanks!
Lon
'65 MG Midget
JPSmit
I don't have an extractor and am pretty sure I just needed a big screwdriver and a dead blow hammer.
C Hub Puller...need picture Please! Austin Healey 4
BillD Front hub puller Spridgets 21
MadRiver Rear Hub Puller? Austin Healey 4
boeingpilot hub puller Triumph 19
J hub puller Triumph 2
J hub puller Triumph 25
hilsideser hub puller on eBay Triumph 3
jsneddon Sidescreen TR rear Hub Puller Instructions Triumph 10
drooartz Front hub puller? Spridgets 8
hilsideser hub puller Triumph 4
drooartz Jeff's hub puller Spridgets 30
Alan_Myers TR rear hub puller? Triumph 10
78Z Hub Puller - what is it used for? Restoration & Tools 5
mctriumph TR2/3/3A Hub cap emblems Triumph 2
D Removing the steering wheel hub Spridgets 12
Carlbanan56 MGB Front hub MG 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
B TR4/4A Steering Wheel Hub Issues Triumph 0
M T-Series MG TD 1st/2nd sliding hub end play MG 1
A BN7 Front Hub Stud Nuts Austin Healey 5
Lin Bugeye Axle Hub & Bearings Austin Healey 1
AUSMHLY Synchromesh Hub End Float Austin Healey 1
W Rear Axle Hub Seal Austin Healey 8
R TR2/3/3A Steering wheel hub removal Triumph 11
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
W Rear Hub Reassembly Austin Healey 7
A Later drum backing plates - hub not clearing Spridgets 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
K TR2/3/3A Front Hub and Felt Seal Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
M Spitfire Triumph spit flange/hub removal Triumph 13
Got_All_4 TR6 Differential side hub measurement Triumph 1
B Wanted Hub Austin Healey Classifieds 4
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
K For Sale TR3 Hub...short studs Triumph Classifieds 0
Rob Glasgow Rear Hub Nuts Austin Healey 11
B TR4/4A 3rd/top gear syncro hub Triumph 2
Sopwith_Camel hub of the action Jaguar 5
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
J TR4/4A Hub out of round? Triumph 2
