Front hub puller
BillD
Member
I need to replace my front wheel bearings ('60 BE) and need a hub puller. Any recommendations and/or advice?
Thanks
They usually come off with out a hub puller. Sometimes (often) the bearings separate.
Jim_Gruber
Yes it's amazing where those little balls have gotten too last time I had the hub off. Bearing just came apart. Even if stuck some careful taps will drive it out most times. Large socket worked for me from other side? I think that's what I used.
BillD
BillD
Member
That's what I was expecting but the assembly is being very stubborn. The factory manual recommends the "18G 146" puller (a lovely little tool) but that's not going to happen. I'm not enthusiastic about just pounding the hub free.
PeterC
You don't need to be enthusiastic, just persistent.
Whack it!
Peter C
HealeyRick
This may help:
from: https://macnugget.org/photos/tboicey_comics/sst
BillD
BillD
Member
Great chart. I'm sensing a consensus building. :smile:
Billm
I often use a Harbor Freight 3-arm puller if it is REALLY stuck but usually a few taps gets it loose.
BillM
G
PeterC said:
I disagree with the equivalency chart....
.... suggest ball-peen over claw.
Peter C
Yeah but you're a seasoned vet. Ya need something to pry back out whatever you just beat too far in. Ya can't do that with a ball. :wink:
Besides, claw is a carpentry tool, much better used doing jobs it was never designed to do...kinda like its' older distant cousin...the brick. :thumbsup:
Bayless
Or to quote from the British-American dictionary, BRSOR (big rock side of the road): an emergency substitute for a BFH. :yesnod:
leecreek
Put the tire back on with lug nuts loose. Use tire to pull it off.
BillD
BillD
Member
Using the wheel as a slide hammer, it took very little effort and less than 30 seconds to free the hub. Thank you!! :smile: :smile:
Congrats and ... Score one for LEE!
leecreek
You are welcome. Hope it works out for you. Don't lose the spacers and shims.
BillD
BillD
Member
Now that the hub is off, I took off the inner seal and tapped the base of the bearings. In both cases the inner race, basket and balls came out but the inner races stayed in the hub. More tapping didn't seem to help so I'm soaking the assembly overnight to try to loosen things up.
Two questions. 1) Is this normal? The bearings were making noise and would freeze if I torqued the castle nut to specifications (40 ft-lbs)or much more than finger tight. I'm thinking that they were very, very bad. 2) Any advice on proceeding with this adventure both in terms of removal or insertion of the replacement bearings?
Thanks in advance for the much appreciated wisdom.
JPSmit
You will have to hammer out the inner race - with the hub off, and looking in from the other side, there should be two "slots" let into the back of the hub <the piece the back of the bearing rests again> a big screwdriver & hammer and Bob's your uncle. In terms of re-installing, easiest way is to use a socket that matches the size of the outer diameter of the bearing to push in the bearing (with a hammer) You can also use the old outside of the bearing but it will get stuck, don't ask me how I know.
PeterC
The trick to that is to cut through the outer race with a cut-off tool before you use it as a pressing tool. The kerf allows the ring to come out easily.
Peter C
I have a modified outer race that sits with all my other bearing drivers for just such use.
BillD
BillD
Member
The reluctant bearing races are now out. Persistence and knowledge of those "slots" in the bearing spacer was the key. Thanks a million for those two bits of knowledge. I've cut slots in the removed bearing races to use as bearing drivers for insertion of the new bearings. Thanks a ton for that tip.
I'm flushed with success but think it best to wait for tomorrow for the new bearing insertion step. If anyone can think of general advice or simply warn against stupid mistakes that I'm about to make, please let me know.
Lon_S What hub puller tool works well for the front hub? Spridgets 2
drooartz Front hub puller? Spridgets 8
Carlbanan56 MGB Front hub MG 4
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
A BN7 Front Hub Stud Nuts Austin Healey 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
Jeepster Front hub replacement. Austin Healey 34
R TR2/3/3A front hub seal options Triumph 9
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
C Front Hub Castle Nut Austin Healey 8
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
R BJ7 front hub shim question Austin Healey 18
catfood Removing front hub Austin Healey 6
RAC68 Calculating Front Hub End-Play Austin Healey 32
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
bertl Front Hub Spacer Kit Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
H front hub removal Austin Healey 37
6 front hub options... Triumph 4
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
Willie_P TR 3/4 Front Hub Install - question Triumph 15
J Front hub mystery Austin Healey 0
britndablood To install or not to install Front hub spacer Austin Healey 8
TR4nut Front Hub Felt Seal - Old vs New Triumph 15
D Need a front hub Austin Healey 1
S Front Hub Replacement Austin Healey 7
G Front hub Spridgets 2
TonyPanchot tork settings for 1997 front hub Jaguar 1
TR3driver Front hub balance problem Triumph 17
M Front hub worn out Spridgets 6
Monark192 MGB-GT 67 GT front hub removal MG 10
drooartz Front hub/brake question Spridgets 12
Jim_Gruber Castle Nut on Front Wheel Hub Spridgets 6
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
19_again front hub removal MG 3
