RestoreThemAll
I installed the front hubs on my '63 BJ7. I cleaned and painted the hubs and used new bearings. For the shim selection I followed the advice that I read here on the BCF. I installed with no grease, just some light oil. I used the on/off method that worked fine. Put it together with all four sizes of shims and add/remove until its right. It came down to zero end play then remove 002. That gave just the slightest end play with the castle nut torqued to about 60lbs. It seemed perfect until I added grease. Torqued to only 30 lbs. the hub won’t even turn. Can the grease be adding that much to the shims?
