TR4/4A Hub out of round?
Jerry
We just replaced the bearings in the rear outer axles. The guy that pressed the hubs off bent one, and the other was close. I had an extra hub for the bent one, so proceeded to put everything back together. Testing with a dial indicator shows that the other hub was about 12 thousands out of round. Put the wheel on and you can notice the vibration when running at 25mph. (Car up on jacks). My friend is going to test the vibration out on the road today to see if it is noticeable.
Since this is on the rear, will it cause any damage anywhere?
Do you think I can chuck the hub into a lathe and flatten it out again?
Any other suggestions. I am going to look in my barn today and see if I have another hub also.
Jerry
Merlin63Tr4
If that hub has.012" runout it is time to throw it out.
The vibration will be noticeable and you will provably ruin that bearing you just installed
I know it's too late, but a great tool to remove the hub with no damage is available from Dan Allen (oldhokie) at Windy Ridge Farm.
http://windyridgefarm.us/Triumph-Churchill.php
M.
TR3driver
Great Pumpkin - R.I.P
I've done it on a front hub, don't see why you couldn't do it on a rear hub. The trick is getting it mounted perfectly on-center.
https://i.imgur.com/1DgF2CN.jpg
mctriumph TR2/3/3A Hub cap emblems Triumph 2
D Removing the steering wheel hub Spridgets 12
Carlbanan56 MGB Front hub MG 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
B TR4/4A Steering Wheel Hub Issues Triumph 0
M T-Series MG TD 1st/2nd sliding hub end play MG 1
A BN7 Front Hub Stud Nuts Austin Healey 5
Lin Bugeye Axle Hub & Bearings Austin Healey 1
AUSMHLY Synchromesh Hub End Float Austin Healey 1
W Rear Axle Hub Seal Austin Healey 8
R TR2/3/3A Steering wheel hub removal Triumph 11
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
W Rear Hub Reassembly Austin Healey 7
A Later drum backing plates - hub not clearing Spridgets 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
K TR2/3/3A Front Hub and Felt Seal Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
M Spitfire Triumph spit flange/hub removal Triumph 13
Got_All_4 TR6 Differential side hub measurement Triumph 1
B Wanted Hub Austin Healey Classifieds 4
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
K For Sale TR3 Hub...short studs Triumph Classifieds 0
Rob Glasgow Rear Hub Nuts Austin Healey 11
B TR4/4A 3rd/top gear syncro hub Triumph 2
Sopwith_Camel hub of the action Jaguar 5
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
H TR4/4A Leaking ft hub seals Triumph 5
J For Sale Header, hub caps Spridgets Classified 1
55modified Nardi hub for a BN1? Austin Healey 10
warwick-steve Missing grease cap in front hub Austin Healey 8
Lin Rear Axle Hub Nuts Austin Healey 3
warwick-steve Front hub bearing grease repacking Austin Healey 28
J TR2/3/3A Hole in Rear Hub Triumph 7
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
K Rear Hub Re-assembly Austin Healey 4
R TR2/3/3A Steering Hub Turn Indicator lever Triumph 7
