Starter works fine but car catches after you let off on the starter
Jerry
I was reading the archives about poor starting but the symptoms are different in my car. The starter turns the engine very well but the car does not catch and run till you let off on the starter. This sounds to me like the voltage needed for the ignition system is being used by the starter. Car runs great once it fires.
I put a voltage test on the battery:
1. No load= 12.0 v
2. While starting the car, 10.5-11v
3. Once running and the charging system takes over, 13.8v
The battery is an Optima and there is no date stamp on it, but I am guessing it is 7-8 years old. My next test is to jump the car and see if it starts better. But, any other items you can suggest to test?
Jerry
Hangtown Healey
Try another ignition switch or temporarily a separate ignition switch and separate starter button. Do you have a ballast resistor on the coil for some reason?
J
Jerry
No ballast on the car, I may have an extra ignition switch, I will try that and test the ignition wires.
Jerry
steveg
You could run a temporary separate hot wire from the solenoid connection to the primary connection on the coil (the one from the ignition switch) thus routing around the ignition switch. If the car starts when cranking the ignition part of the switch is bad or the wire is broken somewhere between the ignition switch and the coil.
If there's enough voltage to crank the starter motor, there's enough for a spark, so the voltage may be a little low, but that's not the problem.
RAC68
Hi Jerry,
I also believe you have a faulty ignition switch an suggest the internal key contacts are either out of line or partially burned. When the ignition is turned to the start position, it makes contact with the starter but misses the ignition contact. When released to the run position, it relaxes and realigns to makes contact with the ignition contact to direct power to the coil.
To check this condition, place a voltage meter on the coil and turn the key to the start position. If voltage is not registered at the coil, change the switch.
Good luck,
Ray (64BJ8P1)
CraigC
Being an auto mechanic by day and a Healey enthusiast by night, I too suspect a burnt contact in the ignition switch. Ray has the proper test procedure if you are at home/shop with a voltmeter. If not, a convenient work-around is available if your car is fitted with a starter solenoid with the push button on the back side. Try starting normally. If the no-start while cranking exists, put gearbox in neutral, set parking brake, leave the ignition "on" , open hood and manually activate starter solenoid. If it fires up normally, head straight to the switch.
CraigC
Should be more like 12.5 volts, at least.
Derek, while cranking an engine, the starter motor is putting a huge load on the battery. It is quite normal for a healthy battery with a no load voltage of 12.6 to drop into the mid-10 volt range while the starter spins the engine. How low it drops is dependent on starter, battery, cable and connection condition as well as the engine you are trying to spin. I have a big block Chevy with 10-1 compression in a boat. It pulls in excess of 200 amps cranking. A low compression Sprite 948 probably pulls less than 80. if I were to crank each with the same battery, the Chevy would pull down a lot farther than the Sprite.
Keoke
Replace it.
CraigC
Craig, his battery shows 12.0 volts with no load, not 12.6v.
Ooops. For some reason I thought you were refering to his 10.5-11 volts while cranking. That's what I get for reading a thread at work and responding hours later from home.
Still would not be too concerned with that voltage since cranking volts are perfectly acceptable. Could just be low from repeatedly testing the starting issue.
J
Jerry
Update on the issue: I charged the battery up over night. It read 12.4 when I took the charger off, and 2 hours later was down to 12.2. I put the voltage meter on the coil and during cranking, the meter read 9.5-10, but started right away after charging so not a fair test. Unless you look at the charging of the battery and then a quick start as the test that tells me the battery is weak. So I will wait two days and try again just to prove it is the battery. At least a battery is easier to change than the ignition switch. Besides if I was getting voltage to the coil during cranking, it is probably NOT the ignition switch.
Jerry
RAC68
Hi Jerry,
It is a good sign that power is reaching the coil when the ignition is switched to the start position. However, if the contact is partially burned, the flow of power may not be sufficient for ignition.. As you have in indicated, a fully charged battery putting out spec levels of power will be necessary to test to a conclusion.
I also have an ageing Optima red-top battery and find that a deep charge is required to bring it up to power. Although a charge set to a standard setting will indicate a fully charged battery condition, without being placed on a deep charge non-maintenance charging setting, it will loos power very quickly and could hamper your ignition test with incorrect conclusions.
Good luck,
Ray (64BJ8P1)
J
Jerry
Update on the fix: I installed the new battery and it started like the old days. I kept a voltage meter on the old battery and the voltage dropped below 12v. New battery as expected was 12.8v.
Nice to have it fixed. thanks for your suggestions.
Jerry
Woodie starter works,, but now oil LEAKS !! Spridgets 13
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
