hydraulic lines to seal
sp53
Hi all well I just replaced the clutch master cylinder on my tr3 and the line that goes in the back has a very slight leak. I was trying this morning before work to tighten it down some but could not get a good fit with a wrench. The nut is actually pretty tight. It looks like it needs that famous quarter turn before it breaks. When I get home, I will pull the inspection plate off the back and try and get some more tightening down on it. The line is old and the cylinder is new, so perhaps the flare on the line is not sealing. My question is do people use something like Teflon tape or some other product on hydraulic lines to seal them at the threads. Probably not, I think the seal needs to be metal on metal?
TR3driver
Great Pumpkin - R.I.P
Nope, definitely should seal metal-on-metal; between the end of the tube and the seat inside the hole. The threads aren't supposed to seal.
That's the low pressure line to the reservoir, right ? I had an original one snap in my hands the other day, with only modest tugging on it; so I would just order a new one.
MGTF1250Dave
Aloha,
I agree with Randall. A bigger wrench or over tightening will only break something. The seal is metal flare to the flare in the master cylinder. Trying to further tighten the nut may strip the treads. Loosen pipe fitting and the bolts holding the master cylinder in place. This should give you a little wiggle room to see if you can get the metal to metal seal.
Another possibility is some debris may be in the preventing the a good seal being achieved.
If this is the pipe from the reservoir to the master cylinder inlet it does not see high pressure. As a last resort, a small o-ring in the between the pipe flare and the master cylinder will give you a seal. I've done this as a short term fix until I could get a new pipe. DO NOT TRY THIS ON THE HIGH PRESSURE OUTPUT SIDE OF THE MASTER CYLINDER. THE PRESSURE WILL BLOW IT OUT.
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
Tinkerman Brake and Hydraulic lines Triumph 4
Baz Teflon tape on hydraulic lines? MG 7
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
JimLaney hydraulic line material Spridgets 6
J Hydraulic Brake Switch Internals Austin Healey 19
I General TR Hydraulic lift opinions/info needed Triumph 34
C Bleeding the hydraulic clutch Spridgets 6
Lukens TR2/3/3A My theory about my clutch hydraulic problems Triumph 11
Lukens TR2/3/3A Clutch hydraulic problems Triumph 12
M 948 clutch hydraulic line Spridgets 7
W Hydraulic Tank Austin Healey 8
catfood Hydraulic cylinder repair. Restoration & Tools 2
texbears3 TR4/4A Hydraulic Fluid Contamination Triumph 10
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
GBRandy Wedge TR8 Hydraulic lifters - Replace? Triumph 1
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
Lin 4-post lift hydraulic fluid Austin Healey 5
stretchit2 Hydraulic Shock Fluid - Bilstein Shock Conversion Austin Healey 6
TulsaFred Hydraulic system disassembly-reassembly Spridgets 10
M TR2/3/3A TR3A Hydraulic system problem Triumph 4
Moseso Weird Hydraulic Failure Triumph 8
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
M Hydraulic Problems Spridgets 5
I Bugeye hydraulic problems Spridgets 9
JohnnyMead Another Hydraulic Fluid Reservoir Question Triumph 10
angelfj1 Paint Quality - Hydraulic Fluid Reservoirs Triumph 14
R BE Hydraulic Question Spridgets 15
Ohiobugeye Another Clutch Hydraulic Line Question Spridgets 2
ekamm New hydraulic resevior Triumph 5
Ohiobugeye Got Engine Running, But have Hydraulic Leak Spridgets 2
Ohiobugeye Hydraulic Bleeding Sequence Spridgets 7
F Dirty Hydraulic Fluid Austin Healey 7
bluemiata90 CLUTCH HYDRAULIC HELP Triumph 9
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
S Hydraulic Brake Switch Austin Healey 5
knad2208 Hydraulic Clutch Fluid Spridgets 1
F Hydraulic clutch adjust Triumph 9
philman hydraulic lifters Restoration & Tools 5
M Hydraulic brake light switches Jaguar 2
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
mrsprite Clutch hydraulic woes Spridgets 32
G Bleeding the hydraulic clutch Spridgets 36
martx-5 Clutch Hydraulic Pipe Routing Triumph 5
regularman British brake hydraulic fittings? Spridgets 9
71tr clutch - hydraulic throw out bearing Triumph 13
