Apparently I can't insert an image unless I start a new post. To see the image, go to my new post "Randall, let's try this"
Have you checked that the clutch pedal always comes back up all the way, leaving some play in the pushrod at the MC? As noted, the entire system is normally under a slight pressure, so any leak would be fluid out rather than air in. The only way I can see for air to get sucked in is for the 'foot' valve in the MC to not open when the pedal is released. Possible causes might include the little wavy washer being missing, or the pedal pivot being sticky, or even the pushrod adjusted a bit too long (especially if you have the pedal stop on the bracket).
Rhttps://i258.photobucket.com/albums/hh260/TR3driver/Manual%20pages/Fig4clutchMC300dpiannotated.jpg
Randall, help me out here. From the diagram, I just can't understand the workings of the valve seal. I understand that this diagram is for an integrated MC body, but it's virtually the same as mine with a separate reservoir. Here's what I "assume":
1) when the pedal is pushed, the seal is closed, forcing fluid to the slave.
2) when the pedal is fully depressed the valve opens. What is happening then?
3) as the pedal is released, fluid is allowed to "return" to the mc under pressure from the slave. It appears to me that if the slave were slow to return there will be a vacuum in the master. Would this not be a condition for air to enter the system?
Obviously I'm not seeing something. Educate me please.
