HOW TO change a ring gear with pics ; ]
zimmy
first spend about an hour drilling through
the ring gear...i used a 1/4 inch bit, then
after i got a good start i moved to a slightly
larger bit.....drill all the way through the ring
gear but NOT into the flywheel.....
NEXT take a hammer and chisel or 2 hammers as in my case,
and split the ring in the drilled out spot...it will "snap"
right off when you get it right........
NOW insert your fly wheel into the freezer and put your new ring gear in the oven and turn it wwaaaayy up to 570+ degrees....mine only reads to 350 so i kinda guessed at it...now would be a good time to try out your fire extinquisher or prepare a snack for your soon to be preheated oven...; )be sure to put the geared edge down for easier movement later....cook about 30 minutes more or less...
when everything is ready...put on your leather gloves and
QUICKLY grab your flywheel, then with a pair of big pliers grab the ring from the oven....RUSH to your predetermined spot......lay the ring level onto the flywheel...
THEN try to hit both sides of the ring at the same time to get it to snap on....the QUICKLY go around it tapping to seat it good......it will be cool in no time....only took me 2 trys ; ) .. .....thx for reading........zzzimmmy /ubbthreads/images/graemlins/cheers.gif
Platinum
Right Arm Zimmy!!!
Congrats! The "time" threshold always had me worried, but usually if ya get it lined up well it'll go on easily.
regularman
Why 570 degrees? If you get it hotter than that will it mess up the ring gear? I like to put wrist pins in connecting rods that way. Then there is no risk messing up some new pistons. Instead of a freezer I used R22 refrigerant, but that was the good old days. Puts it at about 20 below zero in a hurry.
zimmy
zimmy
according to Chiltons 572-752 degrees F..........
392 degrees F for the 1500cc motor....
i have a 1275...........zzimmmy
jlaird
Mine went on easy, I took it to a machine shop and had the surface ground at the same time. lol
ThomP
The Austin Healey shop manual I have recommends 1600 to 1650 degrees! I happen to have an oven that can do that temperature. The starter ring comes out of the furnace cherry red and drops straight on a room temperature flywheel, no hammering required.
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
D TR2/3/3A Why it is important to change brake fluid Triumph 4
C MGA Change a pull starter to a push button system MG 6
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
T BJ8 Fan Belt Change Austin Healey 7
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
T TR4/4A Core Plug - Cam Rear change Triumph 7
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
M Change LHD for MOT Other Cars 2
R Master Cylinder change working Austin Healey 12
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
davidb AH 3000 - vinyl colour change Austin Healey 7
6TTR3A TR2/3/3A Production Change Triumph 7
Michael Oritt Oil Change Problem Austin Healey 27
M MGB trying to change rotors - dumb question MG 7
C Color change...impact on Value? Austin Healey 24
JPSmit How often do you change your spark plugs? Spridgets 7
Basil Admin Note One more little change MG 1
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
E Oil Change Austin Healey 1
dcoplan Spark plug and oil change question Spridgets 9
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
toysrrus What? I`ll have to change my avatar again! Triumph 13
hondo402000 Oil Change Triumph 6
Moseso A simple oil change gone South Triumph 16
J Any reason to not change the color of a Sprite? Spridgets 10
Gliderman8 Oil Change.... When to do it? Triumph 17
Marvin Gruber T-Series TD diff change & wire wheels MG 9
Anthony_S Oil Change Triumph 13
5 BN4 cylinder head casting change date? Austin Healey 5
AUSMHLY When to change oil ? Austin Healey 12
N Head Change???? MG 2
Woodie TR6 tr6 oil change Triumph 5
Rut 1275 oil change Spridgets 6
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
drooartz Time for an oil change: filter and jack stands MG 7
