TR2/3/3A help needed! fuel problem
Kleykamp
I had a distributor with a bent shaft once which allowed the cam to wobble. Points were not opening on two of the three and one opened way too much. Spin the engine and watch the cam to see if it wobbles.
sp53
Well if this is a new engine with rings that need to seat and you have all that gasoline running into the oil or even a blown out diagram on the fuel pump letting fuel into the engine then get that oil out of the engine before you do anymore testing. It is probably 50% gasoline by now!! Like said, recheck the valve clearance to make sure you have compression to firer the cylinder.
peaceout
T
Triguarin
Such a problem had never occurred to me! Thanks for posting I feel convinced this could be the same or similar issue. An early post suggested flat lobes due to wear.....logically it answers many questions.
T
Triguarin
peaceout
Yes, the oil is going to be dumped before more investigation.
charleyf
After reading through this thread again I am assuming that the engine has been rebuilt and reassembled. If so could you possibly have the cam 180 off? If you are using a MG distributor cap could you also have a MG distributor ? Though they look alike they are generally 180 degrees different. That can be changed but is not a normal practice. Try determining if the spark for number 1 cylinder is actually occurring when the rotor is pointing at number one. Likely somebody else can give you a more descriptive test to make sure that the firing order is correct.
I say this because I acquired a Accuspark distributor and rebuilt my engine with it. It would not take a normal Triumph cap but rather one that fit an MG. When that distributor died on me I had to use a regular points distributor and it turned out to be 180 off. So i had to rewire the cap to match the 180 degree difference.
A Fuel Gauge - Help Needed Austin Healey 18
Jim_Gruber Fuel or Electrical - Help Needed Spridgets 1
Jim_Gruber Help Needed - Fuel or Electrical Spridgets 16
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
Lukens TR2/3/3A help needed Triumph 6
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
M Help Needed. Alternator Question Spridgets 14
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
