Front Shock question
Tim Tucker
I received new front shocks (not koni) for my TR4. I checked their resistance and found that they both had dead spots when reversing direction. This isn't normal...right? My Armstrong Super Blue (vintage '86) shocks feel as good or better as these asian made units. I guess koni is the only quality choice we have. Correct? TIA.
Tim Tucker
Platinum
I'd go with Koni's or Spax.
TR4nut
I have Spax and they work fine for me.
With your new shocks, cycle them a couple of times and see if the problem with the dead spot goes away. Not sure of how the internals work, but I found that when I picked one up that had been sitting for quite a while it had minimal resistance on the downstroke, but a couple of pumps and it worked smoothly in both directions.
Tim Tucker
Tim Tucker
I get old and forget stuff that I knew before...:smile:
I didn't have the units in the vertical position when testing. Once vertical, they did fine after a few cycles. I'll have to re-test my Armstrong now..:smile:
Thanks for the responses. I'll get spax or koni one day...I realize they're the best.
Tim
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
G TR4/4A Front Shock Install Triumph 14
maxwedge5281 front shock absorber mounting Austin Healey 3
L Oil under left front shock Austin Healey 7
steveg Loctite for front shock bolts Austin Healey 20
F AH 3000 front shock mounting bolts Austin Healey 21
C Know this Front Shock BUSHING? FORUM Navigation Questions 0
D DIY - Front tube shock conversion Spridgets 33
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
R Front shock bolts Austin Healey 17
George Zeck Front Shock Upg Other & Upgs nearly done ....... Spridgets 18
M Front Shock Mounting Austin Healey 0
L Front tube shock kits MG 13
hymodyne GT6 correct front shock for 72 GT6 MK III Triumph 2
Morris Front Tube Shock Kit Spridgets 16
Morris Front shock bolt torque Spridgets 6
Morris A new front tube shock kit Spridgets 5
M Front Right Shock Change Creates another Problem Spridgets 11
J Front shock removal for seal replacement. Austin Healey 3
K TR2/3/3A TR3 Front Shock Install? Triumph 2
tosoutherncars Front shock R&R instructions / pix / DIY? Spridgets 10
I TR6 TR6 front shock help Triumph 2
E BE front shock bolt clips Spridgets 6
19_again GT6 GT6+ front shock Triumph 3
bighealeysource 100-4 front shock replacement Austin Healey 2
P front shock installation help Spridgets 2
djk Proper length for sprite front shock arm Spridgets 17
MadRiver Front tube shock conversion? Austin Healey 2
cutlass29 Spitfire Spit front shock top nut Triumph 5
S Front shock and swivel axle gap Spridgets 3
Shinsen774 My Left Front Lever Shock is Leaking MG 11
middleagecrazy Front Lever shock arm Spridgets 12
J I need a dimension on a front shock for BJ8 Austin Healey 2
Morris Front Tube Shock Mount pic Spridgets 14
A 76 B front shock absorbers MG 3
HAN8L1965 Front Shock-How should a good one feel? Spridgets 9
WME TR4/4A TR4A Front and Rear Shock Part Numbers Triumph 1
J Front Shock Shims? Spridgets 27
DerekJ Front Shock bolts Austin Healey 13
txtr3 TR2/3/3A Broken front shock mount on TR3 Triumph 4
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
R Front shock absorber arm seal replacement.... MG 1
R Front shock replacement and new bushingS Spridgets 3
G Front Shock Replacement and Early BJ-7 Brake Pads Austin Healey 5
B Front Shock and Bushings MG 13
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
