Front Tube Shock Kit
Morris
I thought you guys might like a look at the bolt on front tube shock kit I made for George Zeck before it's boxed and shipped.
Morris
Morris
I will try to take some pics of it installed this weekend. As for $... I am still working on the math, but I figure in the $200 range.
George Zeck
Morris -
I can come what little hair I have with those. They're pretty. Looking forward to the project.
Tx-
George Zeck
DWeeB
Wow, that looks cool. I'd be interested! Can't wait to see them installed.
Morris
Morris
I was dealing with car break down nightmares all weekend, and I am still one car down. So no pictures yet. Maybe next weekend.
Sorry.
Morris
Morris
Finally got around to doing the math on materials expenses. It looks like the kit will cost $170. The shocks the kit uses run $17-$25 a piece. Shipping is $10.40. So the total price for front tube shocks is $230.00. That's a durn site cheaper than any other front tube shock set up I have seen. :wink:
Morris
Morris
Pictures at last!
This is a daily driver car, so please excuse the schmutz.
Morris
Morris
Re: Pictures at last!
Thank you guys. I am a bit overwhelmed right now... wife is having health problems... and so are all 3 of my cars. :frown:
I will let you know when I am ready to start production again.
R
RonMacPherson
Query, the shock mounting bolts, I hope, are high strength... Mazda went to a single bolt through on their latest batch on the rear.. Which by itself is an engineering faux pax, referencing Carroll Smith's books... But found out that Mazda is using a special(supposedly super hardened) bolt.. But it needs to be not too brittle or it may snap.
Alternative way would be to fabricate some sort of ushaped bracket that would cover both sides of the shock throughbolt.. That would spread the loads better than through the shock mounting bolt.
davester
What exactly is the advantage of using this kit? My understanding is that the most significant weakness of the spridget front suspension is the lack of upper arm triangulation and the bad camber angle. My intention is not to rain on your parade Morris, but this kit doesn't appear to rectify either of those so I wonder why one would want to install it.
Morris
Morris
The shock mounting bolts are M12x1.75 grade 10.9. I have driven over 10,000 miles on this set up and the bolts show no signs of fatigue or wear.
The advantage of this kit is that the tube shocks improve the handling of the car. It is much stiffer in corners and smoother on the highway. I have tube shocks on all four corners and I love the way my car performs. Previously I had non-rebuilt lever shocks that where in good condition. The difference in handling and ride is night and day. I found the ride and handling with lever shocks to be sloppy at best.
Whether tube shocks are better than a good rebuilt stock damper is a point of extreme contention. I prefer the feel of tube shocks over the lever shocks. Many people feel strongly that the stock levers are superior. But very many people believe that their car will be improved by upgrading to tube shocks. My kit is intended to serve those people without bankrupting them.
As for upper link triangulation and camber, I am working on that problem as well. But it is going to be some time before I crack that nut. It's easy enough to manufacture a new upper link. The challenge is manufacturing it in such a way that it will be affordable to the average Spridgetteer. I think many of us would like to install the Frontline kit, or something like it, but the price tag is too $$$.
As for supposed "engineering faux pas"... if you are bothered by them, I recommend you stay away from Spridgets. :wink:
R
RonMacPherson
Stay away from them??
I have a driver 6 and two project 6's...
Morris
Morris
Ha! You have the illness, my friend! :thumbsup:
My wife told me that *if* we won the lottery, I would just blow all our winnings on British car junk.
She really really gets me.
Scott_Hower
Smith would never sanction any suspension component mounted in single shear.
The stuff held in tension looks good to me.
D DIY - Front tube shock conversion Spridgets 33
L Front tube shock kits MG 13
Morris A new front tube shock kit Spridgets 5
MadRiver Front tube shock conversion? Austin Healey 2
Morris Front Tube Shock Mount pic Spridgets 14
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
F TR2/3/3A Tie member[front apron support tube] Triumph 11
newmexTR3 TR2/3/3A TR3 front cross tube needed Triumph 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
