Front Tube Shock Mount pic
Morris
As promised, here is the pic of my tube shock conversion. It's hard to see much in the picture, but the upper mount is bolted to the top of the stock lever shock, and the lower mount is attached to the spring pan.
I am hoping to manufacture and sell this as a kit. Whatta you guys think?
aeronca65t
My conversion looks roughly like your's. With the shock behind the suspension, the caliper can get very close to the shock...one of my calipers lightly grazes the shock at full turn (can't recall which side)so I'm careful turning. But in a racer, it's no big deal. Is your's close?
It's a bit hard to tell from the pic but...
Is the upper mount "overhanging" about 4" from the upper shock mount? It looks like it is. Can you also mount it to the inner fender to "steady" it?
How is the lower mount fixed to the spring pan?
Thanks for the picture...fun to do stuff like this (for me, anyway).
regularman
[ QUOTE ]
[/ QUOTE ] I have heard that the spring pan is not strong enough for the force or the shock and will eventually break. I used spacers on the bottom below the pan and mounted some thick steel down there to mount the shock to. I need to take a pic and post it.
Morris
Morris
The upper mount could easly be attached to the fender, but I wanted to create something that was "bolt on." I am going to be doing some tests to see if there is any flex and I will let you know.
Currently, the caliper will rub the shock under certain conditions. I simply need to extend the lower mount about 1/8" and that will be fixed.
My lower mount is attached to the spring pan by 3" grade 8 bolts. The mount, like Nial's, is 3/4" cold rolled steel. The bar rests on the bottom of the a-arm and is held in place by nuts on top and bottom. It seems extremely strong and secure. I will let you know after a I drive it around for a while if it hammers my a-arms or spring pans.
DesertSprite
I'm interested in tube shock kits, as I'm fairly inept when it comes to fabricating things on my own.
Regularman - you should post a picture of yours as well.
Joel
regularman
[ QUOTE ]
Joel
[/ QUOTE ] I will when I get the time. I'm up in Boston right now for a death in my wifes family. Drove up sunday night and going back wednesday morning and work again on Thursday. I'm tired already.
msoylemez
This is the Frontline set-up. The bottom bracket goes under the A-arm and bolts to both sides. Hopefully this will be strong enough.
And you are absolutely correct, the shock is upside down in the pics!
jlaird
[ QUOTE ]
[/ QUOTE ]
Inquireing minds want to know, in fact must know, why are the shocks upside down, or is the car upside down? LOL I do stuff like that all the time.
regularman
[ QUOTE ]
Kim:
Your setup looks very similar to mine.
Go here to see my setup:
https://npmccabe.tripod.com/spritetubeshock.htm
[/ QUOTE ] Hey, I think I copied you. It was a couple years ago when I did this and I searched all kinds of info on the internet and I remember seeing those pictures (or ones very similar). I just used what I had at hand. That aluminum looks really good. I used all steel because thats all I had. I believe I used 1" keystock for the arm that was drilled and tapped for the shock bolt. I have never had my spridget on the road since doing this. I did that while replacing all the bushing with polyurethane and sweating in new threaded parts in the a-arms, repairing the swivel axels, etc. I did all the suspension restoration/upgrades first.
Biff
Kim,
Could you share with us the source for "new threaded parts in the a-arms", i.e., outter fulcrum pin bushings. I thought I saved a 'source' for them but cannot find it!
Thanks,
regularman
Um, I got them from a place called "apple" something or other. They were not that expensive. I had more trouble finding some good silver solder that I could use to sweat them in. apple hydraulics, I believe, but don't swear by that. Do some google searches and you might find it or someone else might know better than I.
D DIY - Front tube shock conversion Spridgets 33
L Front tube shock kits MG 13
Morris Front Tube Shock Kit Spridgets 16
Morris A new front tube shock kit Spridgets 5
MadRiver Front tube shock conversion? Austin Healey 2
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
F TR2/3/3A Tie member[front apron support tube] Triumph 11
newmexTR3 TR2/3/3A TR3 front cross tube needed Triumph 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
