BE front shock bolt clips
erstearns
I finally started putting pieces and parts back on the old girl and decided to put the front end on first. Digging thru the bags of parts looking for the six mounting bolts I found four y shaped spacers or shims. What are they for, where do they go and why are there only four? My shop manual is back at the house (I know dumb place for it considering it is five miles from my garage). :madder:
JPSmit
flux capacitor?
E
erstearns
Unfortunately, even Dr. Brown could not cause a BE to achieve the necessary speed for TT, even with the flux capacitor.
The part in question is the same as that used to shim up the A arm on a good old made in the USA road wagon. I don't see any mention of them in the manual and I recall they were under the front shocks (I think). PO probably used for some unknown reason. Installing procured rebuilt so will do without.
Not really Y shaped, more like trident with the middle tine removed.
E
erstearns
Was looking thru some old pictures and noticed that two of the "shims" were placed under the shock around the inboard bolt. Any idea why the PO would have shimmed up in such a fashion?
Jake42
Hi Eric,
If you put shims under the shocks, it moves them inboard slightly imparting a bit of negative camber. Maybe this is what the intent was.
E
erstearns
Jake, that is the conclusion I came to also. I found a pic from the disassembly stage and it showed two shims under the inner chock mount. The result would be negative camber or at least less positive, I think. Really the only way to adjust for that effect. I had forgotten where they were and when putting back together was puzzled about the pieces. Mystery solved. Will install rebuilt sans spacers and go from there. I assume this is a well understood subject for the racers in the crowd but had my confused for a moment.
GeeBee1
Yes, they were used to reduce positive camber. Now a days we have offset bushings and offset trunions. In the old days the other trick was to drill out the shocks a bit larger and slide them down/inwards.
Pat
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Morris Front shock bolt torque Spridgets 6
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
G TR4/4A Front Shock Install Triumph 14
maxwedge5281 front shock absorber mounting Austin Healey 3
L Oil under left front shock Austin Healey 7
steveg Loctite for front shock bolts Austin Healey 20
F AH 3000 front shock mounting bolts Austin Healey 21
C Know this Front Shock BUSHING? FORUM Navigation Questions 0
D DIY - Front tube shock conversion Spridgets 33
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
R Front shock bolts Austin Healey 17
George Zeck Front Shock Upg Other & Upgs nearly done ....... Spridgets 18
M Front Shock Mounting Austin Healey 0
L Front tube shock kits MG 13
hymodyne GT6 correct front shock for 72 GT6 MK III Triumph 2
Morris Front Tube Shock Kit Spridgets 16
Morris A new front tube shock kit Spridgets 5
Tim Tucker Front Shock question Triumph 3
M Front Right Shock Change Creates another Problem Spridgets 11
J Front shock removal for seal replacement. Austin Healey 3
K TR2/3/3A TR3 Front Shock Install? Triumph 2
tosoutherncars Front shock R&R instructions / pix / DIY? Spridgets 10
I TR6 TR6 front shock help Triumph 2
19_again GT6 GT6+ front shock Triumph 3
bighealeysource 100-4 front shock replacement Austin Healey 2
P front shock installation help Spridgets 2
djk Proper length for sprite front shock arm Spridgets 17
MadRiver Front tube shock conversion? Austin Healey 2
cutlass29 Spitfire Spit front shock top nut Triumph 5
S Front shock and swivel axle gap Spridgets 3
Shinsen774 My Left Front Lever Shock is Leaking MG 11
middleagecrazy Front Lever shock arm Spridgets 12
J I need a dimension on a front shock for BJ8 Austin Healey 2
Morris Front Tube Shock Mount pic Spridgets 14
A 76 B front shock absorbers MG 3
HAN8L1965 Front Shock-How should a good one feel? Spridgets 9
WME TR4/4A TR4A Front and Rear Shock Part Numbers Triumph 1
J Front Shock Shims? Spridgets 27
DerekJ Front Shock bolts Austin Healey 13
txtr3 TR2/3/3A Broken front shock mount on TR3 Triumph 4
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
R Front shock absorber arm seal replacement.... MG 1
R Front shock replacement and new bushingS Spridgets 3
G Front Shock Replacement and Early BJ-7 Brake Pads Austin Healey 5
B Front Shock and Bushings MG 13
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
