Front shock removal for seal replacement.
John_Progess
I have a seal leaking on one of my front shocks. What is the best procedure for removing the shock from the suspension? Thanks and have a good day!
John
AH100M
Without trying to be nasty, have you tried Section J (that's the right section for 100's, anyway) of the Service Manual? I've followed it for R/R (don't forget the spacer block when re-assembling) and it works. Just follow the directions and stop when the dampers are not attached to anything else. You DO have a Service Manual, don't you?
The absolute safest way is to drop the spring, but it can be done without doing that:
- raise the car up level on four jackstands on a solid (concrete), level surface and remove the appropriate wheel. Make sure the front jackstands are the kind with a narrow, V-shaped saddle, and position the saddle under the wheel end of the A-arm assembly (between the spring plate and the lower trunnion). Make sure the A-arm is securely cradled in the jackstand saddle
- loosen the bolt that holds the shock arms together
- remove the through bolt on the upper trunnion. You'll probably need a drift and hammer for 'persuasion;' be careful not to damage the threads, and be mindful of the powerful spring under compression near the family jewels :wink:
- with the trunnion bolt out and the shock arm clamp bolt loose, you should be able to pull/pry the trunnion out of the shock arms (careful--you don't want to rock the car, spring or no spring)
- remove the four bolts securing the shock
- replacement is the opposite of removal--use a drift or punch to get the shock arm and trunnion holes lined up before you try to push the bolt through
The weight of the car will keep the spring compressed. As long as the car isn't knocked off the jackstands you'll be OK. Since the lower A-arm isn't moved the spacing is retained (you don't need the 2" spacer).
mjobrien
For what it's worth I have followed the recommendation of the manual "Section J" as bill points out with good success.
Whatever procedure you use - Respect those springs they have an amazing amount of energy in them even when slightly compressed.
Michael
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
G TR4/4A Front Shock Install Triumph 14
maxwedge5281 front shock absorber mounting Austin Healey 3
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
L Oil under left front shock Austin Healey 7
steveg Loctite for front shock bolts Austin Healey 20
F AH 3000 front shock mounting bolts Austin Healey 21
C Know this Front Shock BUSHING? FORUM Navigation Questions 0
D DIY - Front tube shock conversion Spridgets 33
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
R Front shock bolts Austin Healey 17
George Zeck Front Shock Upg Other & Upgs nearly done ....... Spridgets 18
M Front Shock Mounting Austin Healey 0
L Front tube shock kits MG 13
hymodyne GT6 correct front shock for 72 GT6 MK III Triumph 2
Morris Front Tube Shock Kit Spridgets 16
Morris Front shock bolt torque Spridgets 6
Morris A new front tube shock kit Spridgets 5
Tim Tucker Front Shock question Triumph 3
M Front Right Shock Change Creates another Problem Spridgets 11
K TR2/3/3A TR3 Front Shock Install? Triumph 2
tosoutherncars Front shock R&R instructions / pix / DIY? Spridgets 10
I TR6 TR6 front shock help Triumph 2
E BE front shock bolt clips Spridgets 6
19_again GT6 GT6+ front shock Triumph 3
bighealeysource 100-4 front shock replacement Austin Healey 2
P front shock installation help Spridgets 2
djk Proper length for sprite front shock arm Spridgets 17
MadRiver Front tube shock conversion? Austin Healey 2
cutlass29 Spitfire Spit front shock top nut Triumph 5
S Front shock and swivel axle gap Spridgets 3
Shinsen774 My Left Front Lever Shock is Leaking MG 11
middleagecrazy Front Lever shock arm Spridgets 12
J I need a dimension on a front shock for BJ8 Austin Healey 2
Morris Front Tube Shock Mount pic Spridgets 14
A 76 B front shock absorbers MG 3
HAN8L1965 Front Shock-How should a good one feel? Spridgets 9
WME TR4/4A TR4A Front and Rear Shock Part Numbers Triumph 1
J Front Shock Shims? Spridgets 27
DerekJ Front Shock bolts Austin Healey 13
txtr3 TR2/3/3A Broken front shock mount on TR3 Triumph 4
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
R Front shock absorber arm seal replacement.... MG 1
R Front shock replacement and new bushingS Spridgets 3
G Front Shock Replacement and Early BJ-7 Brake Pads Austin Healey 5
B Front Shock and Bushings MG 13
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
