middleagecrazy
I have an issue I have been trying to resolve for a few weeks. I was in the process of replacing the grease zirks in my front suspension when I found that the bearing in my left front shock is warn and allowing movement in the connecting arm to the king pin. I have found two other shocks that are good with the exception that the arms on them have slack in them. Therefore I am trying to find out if anyone has found a way to remove the arms that are not warn and loose? I have tried pullers, hammers and heat as well as penetrating oil and WD40 and I can’t get the arm to budge. If I can get the arm off the shock that had the bad bearing I can put it on one of the other shocks that has the bad arm.
Thanks in advance
Anthony
Thanks in advance
Anthony
