Euro carb air filter clearance problems
G
I did a mock up with the stock euro elements and man are they close in the rear, if not touching. Anyone had problems with this? I don't know if my mounts are just saggy or what. I might see if I can shim the motor up 1/2" or so.
Using the choke cable from the 1275 parts car and it looks like it will work out o.k.
scoutll
If you are talking about putting dual SU's on a 1500, most people I know have had to cut a small notch into the top of the right side footwell in order to get the rear carb to clear.
https://www.boicey.com/midget/midget_overdrive.html
Here is an example of a conversion. It shows where and how to cut the car.
Bryan
G
That's for the bowl. I have moved the bolw reaward that it isn't an issue. My problem in the air filter is touching, which it isn't suppoed to. Looks like I have a bad mount. I have two comming so hopefully that will be it. Can't wait for this to be going again.
jfarris Euro Fest 2016 Greenville SC Spotted 4
Geo Hahn General TR British Euro Auto Tour [BEAT] Triumph 2
N Spitfire Joining/mounting Euro manifolds on Spitfire Triumph 3
lbc_newbie Anyone going to Euro Auto Festival in Greer, SC? Spridgets 24
sqbsprite Euro Auto Fest 2011 Oct 15 Spridgets 4
Sherlock Rare metal at our annual Euro Show... Spotted 4
S Pics from EURO-CLASSICA in NC Triumph 1
S Pics from EURO-CLASSICA in NC MG 1
G Which choke cable should I use for euro 1500 carbs Spridgets 8
G 1500 euro carbs interference question Spridgets 5
G Spitfire Best Euro 1500 Spit head? Triumph 0
T Brit Euro Auto Tour Triumph 0
Hap Waldrop MIdget 50th at Euro Spridgets 6
Hap Waldrop Euro Auto Festival, Greer, SC BMW plant, Saturday! Austin Healey 6
Hap Waldrop Euro Auto Festival this weekend!!!!!! Spridgets 5
Kirk_Fisher BMW Euro Autofestival 2007 Austin Healey 2
Hap Waldrop Euro Auto Festival @ BMW Greer, SC October 20 . Spridgets 18
Hap Waldrop Euro Auto Festival, BMW Greer, SC Oct. 20th Austin Healey 1
T Spitfire 'Euro' SU on eBay for a Spitfire Triumph 13
Paul Slice Euro 2006 Triumph 3
B Euro Auto Festival??? Spridgets 1
C Classic Euro Convertible for Photo Shoot MG 0
jackq 2003 Euro??? British Motorbikes 8
Bret Euro Flash! in Road & Track Other Cars 3
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
