Hi
I am installing a HS4 and Euro type exhaust manifold on my 75 Spitfire. According to the parts diagrams and some sketchy information in the service manual, the intake and exhaust manifolds are bolted together on this type of installation.
My question is with the manifolds snugged up to the block there is a gap between the manifolds where the joining bolts are inserted and which when tightened would seem to cause stress on the manifolds and mounting points.
Should there be this gap? Are there fasteners suppose to pull the manifolds together or not? If not, should I shim between them?
I have attached a photo to show the gap. Thanks in advance!
