1500 euro carbs interference question
G
O.K, I know the rear bolw needs some clearance, how about the front? IIRC, somoene said the expansion tank is in the way. Is this correct? I made a little bracket to move the rear bowl and need to know if I have to make one for the front.
The front bowl will interfere with the brass tank. You will need to relocate it. I put mine up next to the battery where the carbon canister used to be. I think how much clearance for the rear depends on how much your motor mounts are sagged. Mine are new and the clearance i cut was a triangle out of the rail with an over all distance of about 4-6 inches and maybe a 1 inch or two deep., two cuts and then i inverted it and used some high tech panel adhesive to re attach it. A heat shield will be needed- I got mine from se hinton on ebay. Here is a real lousy pic-but you get the idea.
G
I won't need to notch for the rear as I have moved the bowl back on the carb. It should clear but haven't tried it yet. I have heat shield already. My tank isn't in right now but I need to put it back so I'll relocated it. I need to order a new gasket, Advance wants $15 for one.
You will never go back to a weber.......
m
RickB
What about HIF4's?
G
I already have these and they are authentic "Euro" carbs ( *snicker*) all polished up and rebuilt. I might go that route later, as it seems I'm collecting induction systems for this thing. If I go injection, it'll probably be off of the SU base platform.
G Which choke cable should I use for euro 1500 carbs Spridgets 8
G Spitfire Best Euro 1500 Spit head? Triumph 0
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
