Jim_Gruber
Yes they all came out of my mouth when trying to fit Bugsy's DS Door after the A=Pillar Skin was welded in last night. All fit fine no rubbing but now front side is rubbing and door once closed will not open. I think issue results from folding over the edge of the A-Pillar skin. I lost some of the extra gap space I once had up front. Other than getting door back open by unbolting hinges, who has some tips on getting this door fitted. Tried loosening bolts on higne straps but they are at their limit.
I need to put a straight edge on the back of the A-Pillar skin to make sure all is straight. Then I guess whack the Hel_ Out of It if it isn't folded over flush with A-Post. I don't see a way on unfolding that A-Pillar back edge if that is truly where my problem is. More research tomorrow morning when I can get back at it again. BFH Time I think.
And I was so proud of the job I did getting all to line up. Grrrr!!!!!!!!!!!! It's the little things!!!!!!!!!!
