Vent Pull Frustration
angelfj1
Anyone who has disassembled the cowl vent lid and mechanism on a sidescreen TR knows the frustration involved in this job. Its kind of tedious and reassembly is not intuitive. OTOH, once this job is finished, there is extreme relief that its behind you. At least that's what I thought! :wall: When restoring the vent lid and mechanism, we decided to replace the actual "pull rod", knob, escutcheon, etc. The repro isn't very expensive and we figured we'd save some time/money. Ha! In the first photo below you see the assembly with the knob attached.
For some reason this assembly is made up from three different metal parts, plus a phenolic knob. The steel wire is snug fit into the brass rod(and pinned), and the brass rod is press fit into the pot metal ferrule but not pinned. We did not recognize this lack of a pin until everything had been reassembled.
The second photo shows the brass rod pulled out of the pot metal ferrule.
I wasn't there to see it happen but I can only imagine the look on Brian's face when testing the vent. Pull once - looks good. Push back in. Pull twice - very nice. Push back in. Pull three!!! Oh - you dirty, no good, blah, blah, blah. That's right! The brass rod/pot metal ferrule came apart, and Brian is standing there with the knob in his hand. He realizes that the vent and mechanism job has to be repeated.
I took the repro unit home to show my wife. My 3 year old grand son was able to pull it apart. There's no way a press fit would have lasted. Then, I had a revelation! Perhaps in their infinite wisdom, the engineers at Canley counted on electrolytic corrosion between the dissimilar metals, brass and zinc(pot metal). Surely there was a reason for selection of three different metals! :jester:
So, a word to the wise is sufficient - check your repro vent pull! :yesnod:
hondo402000
well s..t on me once same on you manufacturer, looks like you will have to drill and pin it yourself, the easy part, redo the installation. Priceless metaphores. but the second time will be easier I promise
Hondo
TR3driver
Great Pumpkin - R.I.P
Makes me glad I made my own, from an old bicycle spoke and a PC board standoff.
Platinum
"Adapt, innovate, overcome!"
I'd be for threading th' beast! I did a similar "improvement" to the choke cable on Her MGB. An old knob for observational originality and a new cable modified to fit the facia, cable and old receiver. The vent rod on the TR is under much more load so Randall's spoke and 'pooter bits would be a good solution. :thumbsup:
Banjo
I went one step further, and purchased an early TR2. So, I don't have to worry at all about the cowl vent, it's not there.
Been into those buggers before though. I agree, not a fun job. very little "finger room" to get all that hooked up.
apbos
I've got one of these for "Statler" when I get done with the B/E.
Paul
tinman58
Mine did the same , pulled apart. Krazy glue works good too...
hondo402000
bicycle shops are good places to get cables supplies, outer cable housing or just the inner spiraly wound cable
Hondo
Banjo
Yup.My local bicycle shop supplied a perfect replacement for a broken outer door handle cable on a Ferrari 308. I asked the guy, after I paid for the cable, "Did you know you sell Ferrari parts?".
Platinum
:lol: I've done that as well, Ben. They always look at ya funny, tho.
I've restrung Italian window regulators with stainless cable for rigging sailboats, too. :wink:
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
S TR2/3/3A vent lid rubber Triumph 11
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
K TR3A Air vent under grille on Race Cars? Racing 5
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
J BJ8 Float bowl vent pipes Austin Healey 11
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
M TR2/3/3A Air Vent Drain Hose Triumph 5
P TR6 Air vent hose clamp Triumph 0
S Question: Works Vent, how to fit Austin Healey 0
P Rocker Cover Vent Spridgets 22
D footwell vent Jaguar 3
T Bugeye Sprite defrost vent installation question Spridgets 18
D TR2/3/3A Demisterr vent routing Triumph 6
O TR2/3/3A Fuel tank vent Triumph 1
C Driver's side defroster vent FORUM Navigation Questions 1
D TR2/3/3A Vent lid link length Triumph 8
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
B TR2/3/3A Vent cowl lid mounting points Triumph 3
M TR4/4A Vent lid fit......is this acceptable? Triumph 11
