TR2/3/3A Fuel tank vent
Oldpine47
The tank I got with my TR does not have a hole in the top for a vent. The tank came with this car when I bought it out of a barn in WV. It looks original but I do not understand how it was vented. Do I have to drill out for a new banjo bolt, or am I missing something?
I just noticed a very small hole inside the top of my new filler cap. Could this possibly be the vent?
TR3driver
Great Pumpkin - R.I.P
It will certainly do for one. I've not heard of original tanks that didn't have the banjo fitting, but I've been running with the banjo fitting blocked off and just the hole in the cap for many years with no problem.
(The banjo vent will dump raw fuel on the ground if you make a hard left turn with a full tank of gas.)
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
Tinkerman TR 3 A banjo bolt and fuel tank vent. Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
sim fuel tank sender reading full all the time Spridgets 9
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
L Fuel Tank sender 100/6 Austin Healey 8
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
E TR4/4A TR$ Fuel line from tank Triumph 13
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
B Fuel tank woes Austin Healey 4
catfood BN1 Fuel tank straps Austin Healey 5
TulsaFred Fuel Tank fitting and nipple Spridgets 6
catfood Fuel tank question Austin Healey 1
