TR2/3/3A Vent tube
tinman58
I am curious about the vent tube for the crankcase. I have the offenhauser valve cover with a breather vent added. I would like to plug the vent tube off. Is there any thing that would hurt the motor By doing so?
CJD
The TR3 ventilation is made so air from the radiator is forced into the valve cover vent under slight pressure. The air circulates through and around the internal engine, and then is pulled out the lower road vent tube by a slight vacuum.
The later Positive Crankcase Ventilation (PCV) system used by all modern cars pulls air from inside the intake filter, circulates through the engine, and is pulled into the intake manifold, so that all oil and contaminants from the engine are burned in cumbustion.
In answer to your question, you need a circulation of air in the engine, to remove blow-by. That requires a way for air to enter and a way for it to exit. One vent is probably not a good idea...but it will work. You will just force blowby containing oil all over the top of your engine.
tinman58
tinman58
Thank you . Makes sense. Appreciate the explanation.
mctriumph
You only think your engine leaks oil ,wait till you allow crankcase pressures to build up!!
Also make sure the bracket holding the vent is in good shape. It will fall off if it fails. This
leads to catastrophic engine failure in a short time as most of the oil heads south.
Have only seen it once, but it cost my customer a nice numbers matching motor on his 61 Tr4
Mad dog
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
F Down Draft Vent Tube Plug... Triumph 11
R TR2/3/3A TR 3ACowl Vent drain Tube Triumph 3
jvandyke 1098 vent tube Spridgets 77
M T-Series Is a plugged TD rocker cover vent tube OK? MG 11
AweMan TR2/3/3A Tr-3 fueltank vent tube Triumph 13
KVH Gas Tank Vent Tube/Hose--Necessary? Triumph 8
norcalnewb 1275 Vent Tube Question Spridgets 5
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
S TR2/3/3A vent lid rubber Triumph 11
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
K TR3A Air vent under grille on Race Cars? Racing 5
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
J BJ8 Float bowl vent pipes Austin Healey 11
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
M TR2/3/3A Air Vent Drain Hose Triumph 5
P TR6 Air vent hose clamp Triumph 0
S Question: Works Vent, how to fit Austin Healey 0
P Rocker Cover Vent Spridgets 22
D footwell vent Jaguar 3
T Bugeye Sprite defrost vent installation question Spridgets 18
