TR2/3/3A New engine = frustration
RonR
Over the past several months, I have rebuilt the TR3A engine, transmission ,overdrive, and front suspension; installed a new wiring harness, new exhaust system, new carpet, new door seals, and new door latches. Probably some other stuff that I have forgot.
When the engine was back in the car and the car was driveable, I drove it twice, for a total of a little more than 100 miles. The car has not been started for several months while I did the interior and doors.
Finally, last night I went to start the car, and after primming the fuel pump it started right up. It ran rough for a while. But, after running pretty good for less than a minute at 2000 rpm or more, the engine just died and the tach slowly went down to that sad 0. I have found if I push the gas pedal to the floor when the engine begins to die, the engine rpm still goes down, but then it will struggle around 500 rpm before moving on up to a higher rpm for less than a minute, and the whole process repeats. It did backfire at least once last night, with black smoke filling my garage.
I have around 4 gallons of gas.
The timing, points, valves, and carbs were all set prior to driving it the 100 plus miles.
Any thoughts?
Thanks.
Ron
Brinkerhoff
I'd do a quick visual check for loose connections and the like then pull the distributor cap off and inspect the points, rotor, loose connections etc. before checking for a dropped needle in one of the carb pistons.
TR3driver
Great Pumpkin - R.I.P
Fuel delivery would be my first suspect. Try removing the float bowl lids after it dies and see what you find inside. Should be enough fuel to hold the float near the top; if the float is near the bottom then you're not getting enough fuel from the tank.
Any chance you turned off the fuel tap and forgot to turn it back on? Will it repeat the performance if you let it sit for a few hours? Shine a light into the gas tank and look for the outlet? (FOD in the tank can sometimes float around and block the outlet, then float away and unblock.)
bobhustead
Perhaps a blocked fuel filter or line. Try changing the filter and removing the fuel line before the filter and blowing compresed air backward into the tank. The long sit before the problem developed suggests sediment.
Bob
JerryVV
What color is your rotor? Get a red one. There were black rotors which had either too much carbon in the plastic compound or a loose rivet which caused a short and symptoms similar to yours.
CJD
Black backfire sounds like it's loading up from getting too much fuel rather than too little. So, float level...fuel pressure...choke assembly would be my first checks. At this point it also sounds like your plugs are fouled, so they will need cleaning before trying again.
R
RonR
Thanks for the suggestions. I will check them out this evening and report back.
No fuel tap in the car.
It does repeat the same problems after several hours of sitting.
New fuel tank, but will check inside anyway.
No fuel filter (I bought one to install but can’t decide on the best location. Suggestions appreciated)
Advance Distributers red rotor, of course.
I will check the choke and clean the plugs. I have an aggregate blast spark plug cleaner.
Ron
sp53
The last tr3 I did I put a new fuel tank in from a southern Cal gas tank specialist and that put about a tea spoon of weld byproduct into each bowl. In addition, I keep about 3 sets of plugs around until I get things sorted out. Do the old unhook the fuel line and see the fuel pressure. I think somewhere somebody here has mentioned the problem, and sometimes the problems are plural.
CJD
Ron
If there's no filter at all, there's a good chance your getting junk blocking the float valve spuratically, so the bowls over-fill.
R
RonR
What is the best location fo a fuel filter on a TR 3A?
Prior to the engine rebuild, I did drive the car for several years with the new gas tank and no fuel filter.
R
RonR
Update:
No fuel in the float bowels. Floats set correctly and needle and seat working properly.
No blockage in the fuel line between the carbs and fuel pump.
Fuel pump glass bowel was full of pure clean gas.
I removed the fuel line from the tank to the fuel pump and gas flowed freely the full area of the fuel line.
Cranking over the engine with the fuel line removed from the front carb float bowel, there is a very small and slow stream of fuel from the fuel line.
My guess is the there is either a blockage in the fuel pump, or my wonderful Victoria British 4-year old fuel pump has decided to stop working.
Since the car ran great for over 100 miles, I don’t think the fuel pump arm was installed incorrectly onto the cam shaft during the engine reassembly.
Thoughts?
Thanks.
Ron
TR3driver
Yup, sure sounds like a problem in the pump. Should be a very definite spurt at the outlet, as the pump only puts out fuel on every other engine rotation.
I ran for many decades with only the stock "filter" (the sediment bowl plus the screen in the top of it). It lets very little crud through. Only time I had trouble with float valves getting blocked by crud, the crud proved to have come from the soft lines near the carbs (which IMO should be replaced every decade whether they need it or not :smile: ).
However, I did finally install a paper element filter after finding some very fine silt outside the carb jets. (Very likely debris from having the car painted with the fuel cap off. Next time I'm going to plug the tank shut myself ! )
BTW, the sediment bowl should stay full even when you're out of gas. The outlet is deliberately at the top (so it doesn't suck up any water or sediment in the bowl). So even if the pump is sucking air through the bowl, the air just goes inlet to outlet and the bowl stays full of fuel.
Geo Hahn
...However, I did finally install a paper element filter after finding some very fine silt outside the carb jets...
This is the one I use on my non-TR - should also work on the TR3-4 fuel bowl:
https://www.bpnorthwest.com/fuel-filter-glass-bowl.html
DavidApp
Update:
Thanks.
Ron
Have you removed the outlet line from the fuel pump and then cranked the engine?
David
Brinkerhoff
Maybe the valves in the pump have stuck shut with varnish. I'm just reviving a 56 Buick that needed the fuel pump taken apart and cleaned.
D Frustration 401 Engine/Tranny Triumph 1
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
