After searching this subject, I found a discussion but no actual answer for front and rear attachment points for engine removal. Time does not allow me to order the front eyelet. Either the front or rear head studs (with head attached). seem viable, but they are both on the same side of the block which would cause side tilt. I will remove engine and tranny as a unit. I have done this before a couple of decades ago, but I can't remember what I used for the rear attachment point. (Unfortunately, I can't remember a lot of other things as well.}
