MGB '68 MGB Engine Removal Questions
AngliaGT
Decided to strip out the '68 - hopefully someone will save the body.
I've got (almost) everything disconnected.
On the drive shaft - if I leave the short section on the rear of the trans,
do I have to do anything to keep the trans from leaking out the output shaft?
What's the best way to store the engine - front forward,or back.I may
need to get to things at a later date.
- Doug
AngliaGT
AngliaGT
Also - what's the best way/place to attach lifting chains
for the engine hoist?
- Doug
drooartz
For lifting chains I've used the rocker cover bolts (remove the rocker cover first) -- at least on the a-series engines this was the factory method. I've also used an exhaust manifold stud for that side, and whatever seemed handy on the other side. I've mostly done a-series engines, but they're very similar to the b-series in the MGB.
Can't speak to the trans -- last one I pulled just leaked. As for storage, I used a cheap furniture dolly under the engine so it could roll around.
Mickey Richaud
Ditto what Drew said.
As for the transmission question, what's your purpose in splitting the driveshaft? Why not just disconnect the yoke? As for leakage, if the seal's bad you may be able to minimize that by tilting the transmission a bit forward.
Jerry
I drained the tranny before I pulled the unit. I was pretty sure it had not been done in 50000 miles. Since we were going to use new engine mounts, I just sawed through the old ones. Much easier than trying to get the rusty bolts out.
Grantura_MKI
Just a quick response. Disconnect the battery, remove everything from the head, ie the intake,exhaust, heater valve, rocker ass, and head. Remove top tunnel cover, shifter,and bolts the attach the prop shaft,disconnect clutch slave bolts, Remove trans member. Lift front of car and attach lift directly to the top of the motor. Lifting angle needs to be steep.
May have missed a bit, but you will get there!
If not done already, pull the radiator,heater pipes,etc. watch the front support when removing the unit.
boxofparts MGB MGB Engine removal MG 5
V MGB MGB engine removal.... MG 1
S MGB MGB engine conversion MG 27
M MGB Early MGB engine compatible with later transmission MG 2
D MGB 1963 MGB engine rebuild MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
G MGB Sick 1967 MGB Engine MG 1
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
Hap Waldrop MGB MGB 3 main engine porn MG 15
toysrrus MGB `79 MGB Rdstr. Engine Bay Pics Needed: MG 3
BugeyeNJ58 Outrageous custom MGB - with Corvette engine. Spridgets 16
B MGB MGB tachometer erratic, engine cutting out.... MG 11
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
S MGB MGB engine mounts - "extra" plate? MG 2
S MGA 5 bolt MGB engine conversion into a MGA MG 2
T MGB Engine Rebuild on 74 MGB MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
vping MGB MGB Engine Block Casting Numbers MG 2
aeronca65t MGB MGB engine work MG 3
T MGB MGB engine differences? MG 7
R MGB 80 MGB engine earth strap MG 11
R MGB MGB engine starting problems MG 9
Monark192 MGA MGB engine in an MGA MG 8
LeeMcKee MGB Engine Color MGB MG 2
S MGB-GT 1975 Engine in '71 mgb gt MG 2
PAUL161 MGB Highest Preformance Stock MGB Engine? MG 8
R MGB-GT MGB GT won't start after engine is warmed up MG 3
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
M MGB MGB VIN and ENGINE #'s MG 5
GreenHornet MGB MGB Beer Engine! MG 9
D MGB New engine for the MGB MG 4
M MGB 1964 MGB 1800 engine MG 1
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
T MGB '79 MGB engine mount replacement question. MG 0
J MGA MGB engine for MGA MG 15
L MGB MGB Engine Problems Again ? MG 10
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
