Tim_Creger
Member
I've got a 1972 MGB with a stage 2 professionally built 1800 by Ivor Searles Engines of England. I just bought this car this summer, and have been struggling with keeping it running since August. I have reset the Weber DGES 38/38 to factory specs, and believe it is not the cause of the problem. I am now down to suspecting either the coil or distributor system. Here are the symptoms:
Starts well cold (imagine that!), runs out smooth and strong when cold (another amazing thing for a LBC). As the engine warms up, probably 10-15 minutes worth of driving, it starts to cut out under excelleration, then as it goes on it is doing so in all gears, all loads, and all rpm, even idle. The electronic tach is bouncing up and down this whole time, but every so often, especially when I romp on it, it will take off with little noticeable problems, but once leveling off starts to buck and cut out again.
Any ideas? I am suspecting worn points/rotor, cracked cap (which has been inspected and I can't see any visible cracks or spark tracks), a worn coil, or a worn distributor shaft in combination with any or all of the previous three.
Tim C.
Tim C.
