Wedge Need help diagnosing a misfire / stutter / stalling when stepping on gas
justin_mercier
I picked up a TR7 just over a week ago and it has one problem which I have not been able to figure out myself. When steppping on the gas the engine hesitates / stalls / misfires. Stepping on the gas slowly to rev it up the engine purrs happily, but step down on the gas quickly or with any pressure and it breaks up.
Here's a pair of audio clips that I've uploaded to youtube.
First vid is with a cold engine, having just started it up (water choke has it idling around 1500 when first starting up). when you hear it rev up smoothly is when I'm stepping very slowly on the gas, i then stomp on the gas a couple times and stall the engine out completely.
https://www.youtube.com/watch?v=XbPv4AwnobU
Second video is after letting the engine warm up enough that the auto choke has slowed the idle down (still idles fast, around 1000) just stepping on the gass and letting off, and then stepping on the gas and holding it for a minute, you can hear the engine BUP BUP BUP
https://www.youtube.com/watch?v=TCN770Uy-qY
Today after dealing with the repair shop and picking up my pickup truck after they fixed collision damage, I went and bought a compression tester and figured that I would check the plugs and compression first just to make sure I couldn't determine anything mechanically wrong. Compression looks pretty close on all cylinders, a hair lower on 1 and 2 than 3 and 4, but all within range of eachother.
Cyl 1
Cyl2
Cyl3
Cyl4
The plugs look fine to, the 4th plug looks like the other 3, but the angle of the photo isnt showing the 'clean' side so it looks dirtier, but they're all about the same.
The carbs are brand new from Jeff at Paltech last summer, as are the points and rotor, ignition wires, and plugs.
TR3driver
Great Pumpkin - R.I.P
I couldn't hear anything at all with the first video, and not much with the second. But my first thoughts are:
1) Is the enough oil in both dampers?
2) Is the fuel fresh?
Second video almost sounds like an old VW bug ... could there be an exhaust leak at the manifold?
Healey_Z
I would start with the basics; making sure the ignition side is in good working order, test the coil. Check timing and advance. Check for vacuum leaks. If all that is good, then look on the fuel side. Carbs balanced, 20w in the pots. If all that is good, I'd start looking at the Strombergs. Pull the top off and check the diaphragms.
George_H
Sounds like carbs but I would check timing and the diaphram on the carb. Just pull the vac line off of it at idle, the idle should increase. If not you either have no vacuum or a bad diaphram.
justin_mercier
justin_mercier
So I checked and the dashpots have oil, and the diaphragms in the carbs look just fine. Need to get a timing light so that i can check the timing (i've never checked the timing on an engine before so i'll have to look up some vids) I misted some WD40 over the top of the engine and it didnt speed up any so it doesnt seem to be sucking in any air from where it's not supposed to. Want to get this problem licked ASAP so I can start to do some driving real soon =) Have owned the car for almost 2 weeks now, and I've only put 15 miles on it !
justin_mercier
justin_mercier
So, I think that I've narrowed it down to just the rear carburetor. In this video you can see that if I reach down and hit the throttle on just the front carb, the engine revs up smoothly, but when I hit the rear carburetor it goes PUT PUT PUT PUT.
https://www.youtube.com/watch?v=rWoSwOJdjgA
justin_mercier
justin_mercier
Pulled the tops off the carburetors and inspected the diaphragms and they look perfect and new, even stretching them and looking around with a light I could find no defects. Refilled the dampers with 30wt non detergent after that was recommended to me elsewhere. The fuel pump is a new electric one mounted back by the gas tank and is working fine (so no leaky diaphragm in the mech fuel pump either)
justin_mercier
justin_mercier
Problem has been solved ! So, it took a bit of investigation, but I found the issue... The spring inside the adjustable needle that's supposed to keep the needle pulled up somehow was broken, resulting in the needle falling down a lot lower than it should be, and starving the engine for gas. I took the needle out of another ZS carb I had in the basement, and replaced it, and everything is running great now. Took it for a half hour drive around the back roads while it was warm and sunny this afternoon =)
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
A Need help diagnosing fuel mix problem Triumph 23
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
