Engine removal
RwBlanks
Finally, life seems to be getting out way of me working on my sprite.
I'm going to be pulling the motor and tranny out of my sprite soon, and was just wondering what the best lifting points would be on an A-series motor? And also if any of you knowledgable folks have any tips, hints or suggestions for this task?
Bugeye58
Rob, I use one of the thermostat mount bolts and the top left transmission mount bolt. I remove the valve cover to gain a little extra room for the lift to span.
Some sort of tilt device to attach to the lift makes the job much easier. I have an Oberg tilt lift that has served me very well over the years.
Jeff
jlaird
A couple of tiedown straps with the rachets on them works as well.
Bugeye58
Kim, you can't remove the crank pulley while the engine is in the car. It sits directly behind the steering rack crossmember. I've never had a crank pulley foul anything yet, and I've pulled literally hundreds of these engines.
That's where the tilt unit comes in handy, as you can raise the nose of the engine nearly vertical to get it out. But, I never had any problems either, before I got the tilt lift.
Jeff
regularman
I've had the pulley catch on the hood latch panel coming out and catch on the crossmemeber below going back in. I know I have put a timing chain on without pulling the motor, but I cannot remember if I loosened the mounts and jacked it up or something like that.
regularman
I made my own trans mount for the 5 speed and it is a bear to get the bolts started. I won't pull mine unless I have to. In the UK I pulled motors out of minis with a piece of chain and a long pipe and two strong backs /bcforum/images/%%GRAEMLIN_URL%%/lol.gif I'm much smarter now, I have an electric hoist in my basement.
S TR2/3/3A engine removal Triumph 12
L TR2/3/3A Engine removal questions Triumph 8
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
R engine removal- where to connect hoist? Austin Healey 16
rjc157 TR6 engine removal Triumph 10
M Bugeye engine removal with floor jack Spridgets 14
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
drooartz Looks like I'll get some more engine removal experience Spridgets 31
Bremer TR2/3/3A Heater removal and engine cooling Triumph 11
Kleykamp Transmission/engine mount removal Triumph 4
boxofparts MGB MGB Engine removal MG 5
B Wedge Tr8 engine removal question. Triumph 13
O TR2/3/3A TR3 engine removal Triumph 5
QuickSilver Engine Removal MG 14
jmwuva05 Engine removal again Spridgets 3
Dadandson First Time Engine/Trans Removal Spridgets 18
A TR2/3/3A TR3 engine removal Triumph 9
Stick Engine Removal Strategy? Spridgets 11
R Engine Removal Spridgets 2
chrpark Your opinion- engine and trans removal as a unit? Spridgets 8
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
drooartz Bugeye engine removal is easy! Spridgets 8
VelodromeRacer Can anyone offer engine removal input? Spridgets 19
A Engine removal question Triumph 4
Bruce_B Engine Removal on '59 BE - Question Spridgets 24
J Bonnet Removal for Engine Swap Spridgets 9
drooartz It's out! My first engine removal Spridgets 22
R 78 Midget Engine Removal Spridgets 11
Tullamore Alpine Engine Removal Sunbeam (Rootes) 1
Z Spitfire Spitfire engine removal Triumph 8
V MGB MGB engine removal.... MG 1
S 68 XKE ENGINE REMOVAL Jaguar 19
B engine and trans removal MG 6
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
