Dadandson
1974 Midget. Been to the WIKI site, very helpful. Transmission mounts are puzzling. I removed the two long vertical bolts from the bottom. The two horizontal bolts on the tunnel from the interior. I removed the shifter handle. Now the puzzle. The shifter housing protrudes above the tunnel. I looked closer and saw the strap that wraps over the trans and attaches to the large "VEE" trans mount. Removed the two horizontal bolts and noticed the small mounts that attach to the large VEE mount. Are you still with me? Anyway, I cannot see how the trans will drop low enough to clear the tunnel when I lift the motor? Do I need to remove the small trans mount and pull the large VEE mount? Any help would be appreciated. Thanks
