G
It's getting closer to the time when my new child has to go get properly fixed up, so I'm starting to look more closely at the costs associated with this.
I need an engine rebuild for sure, it's getting worse and worse. I smell like car when I get home now, and I hate it (almost as much as my wife does). The synchro on second is starting to get a bit tired too, so the transmission is also going to need work soon. It's a regular 4-speed box and (if I stay stock) I'd want to put in an o/d unit. Then there is no point pulling the engine and not doing the clutch. I also need a new exhaust system - the Monza is driving me nuts, and the clunking in the rear when I go into reverse could be anything from the exhaust not being on hangers to a new diff required - I haven't checked yet...
Add to that the cost of a supercharger (from whoever gets there with a retail kit first) or engine mods if that doesn't look like it'll happen next year and I'm up to well over 10k. /ubbthreads/images/graemlins/pukeface.gif
At that point a V8 conversion starts to seem quite attractive. Unfortunately there are two problems with this -
#1 I have not enough time, space or welding proficiency to accomplish this conversion at home, and
#2 While it may be easy to throw cash at an MG and turn it into a V8, vendors that will do this to a Triumph seem to be non-existent.
With all that in mind, I have a few questions directed at those brave souls who already undertook this job so I can see if it's going to be a starter, or if I should stop even thinking about it. I'm thinking that a 302/T5 is likely the best option - it sure seems the most popular. I've read (exhaustively) all the sites that describe these swaps, so have some idea of what's involved. I'm going to upgrade the suspension anyway so that's not going to be an issue, and I intend to keep the car so resale isn't a problem either.
Assuming I can find a shop that looks able to do the work:
1. Time? As we know it's money. Anyone care to estimate the number of hours to do the swap. I can then work out a rough first guess at a price.
2. If I go crate engine / new tranny will I still need a donor for other bits? I'll do a carb setup for simplicity.
My final question is directed to anyone in the NE. Do you know of shops that do (or possibly could do) this conversion that you'd feel comfortable recommending?
Or should I just forget it and stay with the 2.5l?
/ubbthreads/images/graemlins/cheers.gif in advance
Alan
Alan
