Floor Pan Replacement Cost
jjbunn
I'd like to get an idea of how much a body shop might charge to replace a floor pan in a TR6. The car I'm looking at has a an area of maybe a couple of inches at most of rust-through at the outside edge of the front-most position of the pan.
Other than replacing the whole pan, is there a good way of patching a hole like that, or is it a bad idea?
I'm assuming (perhaps wildly optimistically) that the rust is confined to the pan /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
TR6oldtimer
Julian, I looked through the pictures you took and noticed that the inner sill on the passenger side was rusted out
and noticed that the PO had replaced the rocker on the same side but not very well. There is a lip on the inner part of the rocker that extends down from the floorboard. There you can see where the rusted area was cut off and a new piece of sheet metal lap welded on (a good shop would have butt welded it). I also noted that the end cap on the rocker at the rear of the car was not installed.
Whether you just cut out and patch the bad parts of the floor really depends on the extent of the rust damage. (Why someone would replace the rocker and bottom of the floorboard, but not the inner sill and rust spots on the floor, is to me indicative of sloppy work that may extend to other parts of the car. )
A complete floor replacement requires the body to come off the frame, a time consuming process. Patches or partial replacement can be done with body on.
I also noted that the bottom of the rear valence has rusted through. Because this area is double paneled it is in my opinion more difficult to properly repair and seal then the floor and inner sill.
If you are not planning on doing the work yourself, I would strongly recommend you find a shop that will do the work and get an idea of the cost BEFORE you buy the car.
I hope this helps. Good luck.
tdskip
The pan isn't the real issue - it is the join where the front inner fender, sill, and firewall meet. The pan maybe also an issue, but that is the real challenge.
You can't know what you are really dealing with until you remove the fender.
Just that area is not rotten...
jjbunn
jjbunn
Hi Ray,
Many thanks for taking a look at the photos. Could you please point to which of the photos you are referring to that show the rocker replacement?
There is indeed a rust hole on the rear valence, just under the bumper, on the driver's side. I was reading on the six pack forum that this is a bit tricky to fix properly. But it's not a structural issue, correct?
Other than the rust spots mentioned, did you see anything else that gave you reservations?
Again, thanks.
jjbunn
jjbunn
OK, yes, point taken. It's all such a lottery this old British car buying business - I have a feeling that if I knew more about it, then I'd never even consider getting into it!
On the other hand, *somebody* has to get this car back on the road, and that person might as well be me /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
tdskip
Great attitude! I'm taking the same approach, but I wanted to make sure you have your eyes open.
TR6oldtimer
Jillian,
Here is the link to your photo and the rocker I was talking about. Notice you can see inside. This should not be, there should be a end cap (commonly refereed to as a cookie cutter) covering the opening.
If you look close at the vertical back of the rocker cavity you will see where a lap joint runs horizontally along it. On a new or properly repaired car you would not see that seam. If the weld goes all along that portion of the floor, the only way to do it is to have the rocker off.
There should also be round drain holes at various locations along the vertical that I do not see.
Someone also sealed the clip and acme screw just in side the rocker cavity. This is not ordinarily done.
https://i239.photobucket.com/albums/ff69/jjbunn/IMG_0128.jpg
jjbunn
jjbunn
Ray: I see exactly what you are referring to, thanks for the detailed explanation.
The jagged piece of metal just below and to the left of the bolt head does not look right, does it? The conclusion seems to be that the panel has been replaced. This would also explain the lack of seam which was discussed in a separate post.
How easy will it be to get that panel off, I wonder?
There being no cookie cutter cap there will mean either any water would drain away more easily, or enter the cavity more easily, depending on if you are a half-full or half-empty glass person /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
TR6oldtimer
jjbunn said:
...The jagged piece of metal just below and to the left of the bolt head does not look right, does it? The conclusion seems to be that the panel has been replaced. This would also explain the lack of seam which was discussed in a separate post.
Good observation. That jagged piece of metal looks to be what is left of the lower part of the "b" door post. Not fatal, but not good.
jjbunn
jjbunn
BOXoROCKS said:
It just dont pay to be a nice guy.
Very true ... but I'm not planning on turning a profit /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
B TR4/4A Floor pan replacement Triumph 4
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
Zitch TR4/4A Floor pan replacement Triumph 18
bugedd Floor pan replacement Spridgets 12
T Anyone used Moss front floor pan replacement panel Spridgets 2
Stewart floor pan replacement MG 34
HAN8L1965 Replacement Floor Pan Spridgets 1
bcbennett Floor pan replacement Triumph 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
F TR2/3/3A Floor pan question Triumph 16
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
S TR4/4A Floor pan mountings Triumph 8
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
C TR2/3/3A Floor Pan Crack Triumph 5
S TR2/3/3A On installing the floor pan Triumph 4
A TR2/3/3A Floor pan measurement Triumph 1
M needed rt. ft. be floor pan Spridgets 1
Psevins TR2/3/3A TR3 Floor pan Triumph 22
P Interior - right floor pan Triumph 8
M Do you REALLY need drain holes in the floor pan? Spridgets 3
B Holes for sets in BJ7 floor pan Austin Healey 2
Jim_Newman BN1 floor pan Austin Healey 6
W Floor pan comparison Spridgets 7
S TR2/3/3A Tr3 floor pan removal Triumph 5
T What do you guys use to cut floor pan sheet metal? Triumph 7
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
chicken Floor pan insulation panel Austin Healey 7
T Should floor pan be replaced? MG 15
F TR6 Rust and small hole on floor pan- TR6 Triumph 6
H MGB MGB floor pan question MG 4
A Rocker panel or floor pan first Triumph 1
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
Healey Nut Insulating Floor Covering Austin Healey 7
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
