TR4/4A Floor pan mountings
shoopal
Can someone tell me if there are any rubber blanking plugs in the 5/8" holes that the bolts that hold the pan to the frame go through?
Popeye
Bronze
Don't believe so ...? I think the bolts and washers go direct from floor pan to frame, and there are shims between floor and frame.
S
shoopal
You are right. I was confused with all the other holes that do need blanking plugs. However in the interests of preventing water getting up, I bought a bunch of flat rubber washers so from top to bottom: bolt,lock washer, flat washer, rubber washer, floor pan, 3 or 4 hole rubber body mounting pad, frame.
I guess I'm getting leak crazy with this thing
S
shoopal
When I inspected the contents of the body mounting kit I found 4 3-hole pads and 4 4-hole pads. Does this mean that there is a pad below the pan and a pad above the pan? There seems to be a recess molded in the pan that would accept such an arrangement. Or maybe the overall thickness would make a bulge in the carpet?
Al
Popeye
Bronze
Experts will chime in, but I believe the multiple pads are used to shim the body into alignment?? I.e. you don't need all of them.
S
shoopal
I do believe that you are right. Refer to the notes on this page which was sent to me by Moss tech support (expand view to 125%)
  • 4701_001.pdf
TR4nut
I was thinking the 3 hole pads are for TR6 but 4 hole were used on TR4.
the rear mount in your picture shows the 3 hole location. On a TR4 that mount point uses 4 holes.
S
shoopal
My 65 TR4A has both types. The 4 hole is forward (to the right) and the 3 hole is in the rear.
TR4nut
Ah yes, those extras are to get panel alignment just right. In fact sometimes it can take more than two pads per location.
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
F TR2/3/3A Floor pan question Triumph 16
B TR4/4A Floor pan replacement Triumph 4
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
C TR2/3/3A Floor Pan Crack Triumph 5
Zitch TR4/4A Floor pan replacement Triumph 18
S TR2/3/3A On installing the floor pan Triumph 4
bugedd Floor pan replacement Spridgets 12
A TR2/3/3A Floor pan measurement Triumph 1
M needed rt. ft. be floor pan Spridgets 1
Psevins TR2/3/3A TR3 Floor pan Triumph 22
P Interior - right floor pan Triumph 8
M Do you REALLY need drain holes in the floor pan? Spridgets 3
T Anyone used Moss front floor pan replacement panel Spridgets 2
B Holes for sets in BJ7 floor pan Austin Healey 2
Jim_Newman BN1 floor pan Austin Healey 6
W Floor pan comparison Spridgets 7
Stewart floor pan replacement MG 34
jjbunn Floor Pan Replacement Cost Triumph 10
S TR2/3/3A Tr3 floor pan removal Triumph 5
T What do you guys use to cut floor pan sheet metal? Triumph 7
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
chicken Floor pan insulation panel Austin Healey 7
HAN8L1965 Replacement Floor Pan Spridgets 1
T Should floor pan be replaced? MG 15
bcbennett Floor pan replacement Triumph 4
F TR6 Rust and small hole on floor pan- TR6 Triumph 6
H MGB MGB floor pan question MG 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
A Rocker panel or floor pan first Triumph 1
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
Healey Nut Insulating Floor Covering Austin Healey 7
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
