floor pan replacement
Stewart
For those who have tackled this job how long did it take you to cut the old pans out and weld in new pans? I'm trying to figure out which way is going to be the most cost effective to complete the job. Doing it my self or hiring a body guy to do the work at 40 an hour.
I'm short of the needed tools not to mention I would have to hire out the welding as my garage has just enough amps to it to run the garage door and a single light.
tony barnhill
Great Pumpkin - R.I.P
Cut the old ones out & glue the new ones in with Fusor.
RTR52nd
Hey Stewart -
I'm also in the process of removing my floor pans, have welding experience and access to the necessary tools, but have been considering Fusor as well.
So, Tony, Have you used it on floor pans, and if so, what is the clamping method? Or, how the heck do you keep pressure on it for 5 hours? Sand bags? Pay small children to sit in your B? I know at least two of us who would love to know!
Thanks!
ccougill
shoot a few sheetmetal screws at various places around the edges to clamp it. they can come back out, or as I usually do, grind the heads off and cover em up with seam sealer.
Platinum
I used pop-rivets. ground 'em a bit after the 'glue' set. I used the SEM "Multi Purpose Panel Adhesive".
This skeptic is now a believer. /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Ooohh! And pay attention when going thru the starboard floor: the wiring harness doesn't take kindly to being punctured/pop-riveted. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
tony barnhill
Yep, listen to chuck - he taught me how to!!
ccougill
Doc I learned that the hard way, there's a brake line under there too
tdskip
So I haven't actually replaced an MGB floor pan (yet) but I had some cutting and welding to do on the MGA. It took me a year to psych myself up for it but I found a mentor and just dug into it. Turned out it wasn't nearly as hard as I expected. Messy and time consuming, yes. Hard, no.
Getting the old boards out is actually fair early from the looks of it.
Maybe we can huddle in Pasadena and have a cutting and welding party!
tony barnhill
On the last set of floors I did, I cut the old floors out leaving about 1" all around the edges & cross members....then, I cleaned that up, test fitted the new floors & used the 1" of old floor as a lip for the Fusor to adheer to.
Oh, I also dropped all my wiring & plumbing away from where I was cutting beforehand so I didn't repeat chuck's uh-oh.
RickB
Wow!
Where do you buy this stuff? (Fusor)
Sounds like a "miracle in a can"!!
tony barnhill
Any good auto body supply house.
Platinum
Yup. Strong as can be. Took me about a day per side to cut the old ones out and glue up the new ones. I too left the "lip" around the pans. Makes a good way to get the new ones right where they should be.
MGBGT_noob
That's why you should make one of these part of any resto. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Rob_Edwards
RTR52nd said:
Hey Stewart -
Thanks!
tony barnhill
/bcforum/images/%%GRAEMLIN_URL%%/lol.gif hahaha...if it works, what the heck!!
BritCarFan
Does the adhesive have the same strength as a weld if the part is used in a strutural area?
jlaird
I would think not good for anyplace that has stress all the time.
Platinum
Ummm, can anyone say: "UH-1"?!!? Glue 'n pop-rivets flyin' in mass formation, kids. Plenty of constant stress there, Jack. Those airframes are still workin'. My MGB would hardly be put to the stress levels the glue is likely to fail at. I bonded a bunch of different metals together with the stuff and tortured it every way I could think of: Impact, tensile and shear. It stuck like, well, like GLUE to the parent materials. Only half bad failure I could point to was a shear failure with aluminum, two strips of 1/8" glued together then after cure time expired I put it into a vice and BEAT it with a hammer to a 50* angle before it let go.
tony barnhill
Factories have almost stopped welding during the new car construction process...glueing is becoming much more acceptable - especially with plastics,etc. taking the place of some metals.....I'd glue any body part to a car!
B TR4/4A Floor pan replacement Triumph 4
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
Zitch TR4/4A Floor pan replacement Triumph 18
bugedd Floor pan replacement Spridgets 12
T Anyone used Moss front floor pan replacement panel Spridgets 2
jjbunn Floor Pan Replacement Cost Triumph 10
HAN8L1965 Replacement Floor Pan Spridgets 1
bcbennett Floor pan replacement Triumph 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
F TR2/3/3A Floor pan question Triumph 16
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
S TR4/4A Floor pan mountings Triumph 8
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
C TR2/3/3A Floor Pan Crack Triumph 5
S TR2/3/3A On installing the floor pan Triumph 4
A TR2/3/3A Floor pan measurement Triumph 1
M needed rt. ft. be floor pan Spridgets 1
Psevins TR2/3/3A TR3 Floor pan Triumph 22
P Interior - right floor pan Triumph 8
M Do you REALLY need drain holes in the floor pan? Spridgets 3
B Holes for sets in BJ7 floor pan Austin Healey 2
Jim_Newman BN1 floor pan Austin Healey 6
W Floor pan comparison Spridgets 7
S TR2/3/3A Tr3 floor pan removal Triumph 5
T What do you guys use to cut floor pan sheet metal? Triumph 7
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
chicken Floor pan insulation panel Austin Healey 7
T Should floor pan be replaced? MG 15
F TR6 Rust and small hole on floor pan- TR6 Triumph 6
H MGB MGB floor pan question MG 4
A Rocker panel or floor pan first Triumph 1
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
Healey Nut Insulating Floor Covering Austin Healey 7
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
