Insulating Floor Covering
Healey Nut
Years ago when I restored my first BJ8 I used a product all over the floors and foot boxes to help keep out the heat and sound .
lt was a thin black rubber product about 1/8” thick with a silver foil type backing . You peeled off the protective film and rolled it down on the floor pans .
I got it off flea bay , came on a roll about 18” wide . I did two BJ8s with the roll and had just enough to do the foot boxes on my BT7 project but I’m looking for some more .
I can’t find it again and don’t have any records of what it was called .
Any ideas anyone?
IT'S NOT DYNAMAT.
You're probably thinking of Dynamat. I bought an equivalent product--made in Russia!--that was cheaper but seemed equivalent to Dynamat. It did my BJ8 with a bit left over. Quality was good (NFI):
I also bought an application roller:
HealeyRick
Bob, their ad only mentions sound insulation. Does it provide heat insulation as well?
John Turney
You could try duct insulation from your local hardware store (Ace, in my case) About the same thickness as you stated, one side is foil and the other side is sticky.
I also used dynamat about eight or nine years ago, on both the Bugeye and the 100. Still working fine. More sound than heat insulation
vette
I believe the best I have ever used is Lizard Skin. There are two products intended to be used together. One for Sound and one for heat. The heat stuff is a ceramic. It is sprayed on and bonds so well that nothing will ever get under it. It is water based and goes on rather wet but drys up surprising fast. It bonds like the best paints and epoxies that you can imagine. It's probably been more that 15 years since I did my BJ7 with it. When people ask how it works, I tell them that I never notice any excessive heat in the car. No heat radiating from engine or trans.
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
K TR4/4A Distributor Points and condensor insulating washers..... Triumph 14
Patrick67BJ8 Insulating Rear Fenders Austin Healey 6
J Bugeye exhaust question - am insulating floorboard Spridgets 2
wkilleffer MGB Insulating MGB fuel lines MG 4
G Carb Insulating Block on 1500cc Midget Spridgets 5
Nunyas Bonnet insulating pad/liners MG 7
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
F TR2/3/3A Floor pan question Triumph 16
B TR4/4A Floor pan replacement Triumph 4
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
J TR2/3/3A Painting floor pans Triumph 2
R TR2/3/3A Trunk floor replacment Triumph 4
R TR2/3/3A Boot/trunk floor Triumph 5
J front cross member height from bottom to floor on BJ8 Austin Healey 5
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
Rob Glasgow Garage Floor Coatings Restoration & Tools 1
S TR4/4A Floor pan mountings Triumph 8
NutmegCT Garage floor Restoration & Tools 19
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
H Uh Ohh, Oil All Over The Floor Austin Healey 33
R TR2/3/3A Welding in the floor questikns Triumph 19
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
S Restoring a bj7 floor issues Austin Healey 3
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
C TR2/3/3A Floor Pan Crack Triumph 5
Zitch TR4/4A Floor pan replacement Triumph 18
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
T Grommet - sling hole in floor - XMSC108 Spridgets 3
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
R TR2/3/3A Installing floor pans Triumph 13
M Bugeye engine removal with floor jack Spridgets 14
TRMark TR4/4A Crack in floor at sill mounts Triumph 5
S TR2/3/3A On installing the floor pan Triumph 4
