TR2/3/3A Trunk floor replacment
Rubicon
so I’m coming to the end of floor and inner sill replacement and have been looking into the trunk floor replacement. The car currently is still on the frame, so I guess do I replace the trunk floor while it’s still on the frame? Or can I do it when I have it off the frame? The spare wheel house is good, the closing panels and extensions are good, just the center section is bad, as well as the section under the gas tank seems to be missing. Am I at a safe point to seperat the body and finish off all the underside welding, as well as trunk replacement.
Thanks
M_Pied_Lourd
I'd probably fit the new trunk floor with the body still on the frame just to be safe....just my two cents.
Cheers
Tush
R
Rubicon
Thanks for the input Tush, i was leaning that way but hoping I could do it off the car. But as you said better safe then sorry
M_Pied_Lourd
Yeah, at least tack it in solidly and then go about your underside welding.
Cheers
Tush
martx-5
I suppose you could do it off the frame, but I did it while still on the frame. The spare tire well has to be supported (by a jack) or it will swing down after you cut out the floor. I cut the old floor out in sections, but when I went to install the new floor, I had trouble getting it in through the boot opening. It just seemed to big to fit. I must've messed with it for 20 minutes or so, until I finally found the sweet spot. I screwed it together temporarily with sheet metal screws while I plug welded it in from the top.
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
R TR2/3/3A Boot/trunk floor Triumph 5
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
M BN1 trunk floor question Austin Healey 4
J Rear part of trunk floor availablity? Spridgets 17
apbos TR2/3/3A TR3a Trunk floor removal and replacement Triumph 20
T MGB-GT Anyone need a BGT replacement trunk floor? MG 0
A BN7 trunk floor markings Austin Healey 10
martx-5 TR2/3/3A TR3 Trunk Floor Triumph 0
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Twit TR4/4A TR4 trunk badge Triumph 8
69MGC MGC Putting a 12v battery in the trunk MG 10
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
aero3113 100-4 trunk liner kit Austin Healey 4
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
JimLaney Refurbishing the trunk lid Spridgets 2
1 Wedge Breaking Into a Trunk Boot Triumph 3
S TR2/3/3A tr3 trunk primer Triumph 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
S TR4/4A trunk seal question Triumph 10
S TR2/3/3A T handle trunk lock Triumph 14
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
aero3113 Trunk Prop Stay Austin Healey 8
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
MisterB And now.... the trunk Austin Healey 12
maxwedge5281 bn6 two seater trunk Austin Healey 16
bcbennett Wedge Bonnet and trunk prop rods Triumph 0
M TR2/3/3A Water in Trunk Triumph 10
69MGC MGC MGC Trunk Thingies? MG 5
Rob Glasgow Armacord Trunk Liner Austin Healey 8
S Trunk Lid Spridgets 26
T TR4/4A Trunk lid lettering - template wanted Triumph 0
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
petnatcar Trunk modification for bt7 Austin Healey 15
magman BN-1 trunk latch adjustment Austin Healey 1
Scotsman TR4/4A TR4a trunk lid Triumph 2
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
S TR4/4A door and trunk seals Triumph 3
TRMark TR4/4A Trunk lid and handle assembly Triumph 7
B Gaskets for Trunk Lid Hinges Austin Healey 9
J TR4/4A Trunk Lid Seal Triumph 4
B Works Boot Rack [ For boot read trunk] Austin Healey 5
John Turney Trunk Lid Control Cable Austin Healey 2
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
