So, while waiting for the undercoat to dry on the right rear fender (the last one, phew!), I decided it was time to move on to the next issue. I had suspected I had corrosion issues on the deck lid. One I got it off, I was correct. The front and rear of the trunk lid had a fair amount of pitting, but little rust, as if there was a previous attempt to clean the trunk lid up. The pitting is very prevalent. Sanding, buffing, grinding, etc. is not bringing it flush. Part of me thinks I should put a thin layer of bondo on it to smooth it out. Part of me thinks it would be best just to clean it up and paint it and leave the pits. Again, I'm not going for the concours. I'm just trying to get ahead of the curve on rust problems and bondo would hide any recurrence of the rust.
Another odd thing was the car is currently up on jackstands for the rear. Both are placed under the forward spring attach point. When I went to open up a door, the doors binded a bit. I had my floor jack under the pumpkin and lifted the car a fraction of an inch. Doors worked fine. Is that kind of body flex typical? That seemed kind of scary, and from what I've read about other convertibles, that is usually not a good sign. Car will be back on all fours again by tomorrow evening.
