TR2/3/3A tr3 trunk primer
sp53
I think I asked this before, but anyway I have old truck lid that is down to bare metal and has bunch of little dings and what I was doing is filling the dings with left over putty on the bare metal. The question is should I have put the epoxy primer down first or should I putty first or does it matter?
HealeyRick
Although we were always taught to put filler over bare metal, current practice is to use epoxy primer first, then put the filler over the primer. Filler must be put over epoxy primer in the window specified by the primer manufacturer or if the window passes, the primer needs to be scuffed. Nevertheless, I have put filler over rust-free metal, then epoxy-primed, followed by primer surfacer and it's been holding for the past 20 years.
CJD
Though it works either way, the current “correct” way is prime first then fill.
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
luke44 TR2/3/3A TR3 Trunk Latch Inner Piece Triumph 11
M TR2/3/3A 1956 TR3 Trunk cover panel Triumph 6
J TR2/3/3A Fabricating TR3 trunk panel,looking for photo help Triumph 16
af3683 TR2/3/3A TR3 Trunk Plugs Near Gas Tank Triumph 3
S TR2/3/3A post 6k tr3 trunk brace Triumph 14
mountainman TR2/3/3A TR3 Trunk panel Triumph 10
newmexTR3 TR2/3/3A TR3 trunk bulkhead install Triumph 7
mcguijo TR2/3/3A TR3 Trunk Flooring Triumph 9
S TR2/3/3A tr3 trunk pan Triumph 8
martx-5 TR2/3/3A TR3 Trunk Floor Triumph 0
