TR4/4A Floor pan replacement
bammons
My chassis and body are going to the shop to get painted. The chassis is hanging from the ceiling and I intend to simply drop it onto the chassis to get it to the shop without any mounting pads. One of the first things they will be doing is replacing the driver side floorpan. Then they will lift the body back off to clean-up and paint. I know that the body needs to be on the chassis to weld in the new one. Here is my question: To get the new pan lined up correctly do I need to install the new body mounting pads first? The old ones are not on the car. I was going to install the new pads when the body is reinstalled after painting but got to wondering if not having them in would mess up the alignment of the new panel. Bruce
Popeye
Bronze
I would not think so.
Might be good to install the doors, or weld in some cross-bracing, (or both) to keep things from moving around.
mctriumph
Watch out for the replacements being for a tr6 ,NOT a tr4. The mount holes are different and must be modified
for use. If your shop has not done a tr4 previously you are in for a lot of fun getting the panels re-aligned
MD
B
bammons
I got the panel from TRF (British Heritage) so it should be good but I will look at the panel today. I will say that I thought they were the same though. Bruce
sp53
They will not need the pads; taking the floors out is real caveman work, from grinders to chisels to spot weld removers to plasma cutters. If you are concerned, tell them to double check the old ones with the new ones because somebody suggested the holes might be incorrect on Heritage panels. That is about all you can do, and trust the process because it is in their hands now. I would give them time, but not too much time plus ask if you can keep an eye on progress. In addition try and not be a cash cow for them. be upfront and honest.
steve
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
Zitch TR4/4A Floor pan replacement Triumph 18
bugedd Floor pan replacement Spridgets 12
T Anyone used Moss front floor pan replacement panel Spridgets 2
Stewart floor pan replacement MG 34
jjbunn Floor Pan Replacement Cost Triumph 10
HAN8L1965 Replacement Floor Pan Spridgets 1
bcbennett Floor pan replacement Triumph 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
F TR2/3/3A Floor pan question Triumph 16
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
S TR4/4A Floor pan mountings Triumph 8
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
C TR2/3/3A Floor Pan Crack Triumph 5
S TR2/3/3A On installing the floor pan Triumph 4
A TR2/3/3A Floor pan measurement Triumph 1
M needed rt. ft. be floor pan Spridgets 1
Psevins TR2/3/3A TR3 Floor pan Triumph 22
P Interior - right floor pan Triumph 8
M Do you REALLY need drain holes in the floor pan? Spridgets 3
B Holes for sets in BJ7 floor pan Austin Healey 2
Jim_Newman BN1 floor pan Austin Healey 6
W Floor pan comparison Spridgets 7
S TR2/3/3A Tr3 floor pan removal Triumph 5
T What do you guys use to cut floor pan sheet metal? Triumph 7
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
chicken Floor pan insulation panel Austin Healey 7
T Should floor pan be replaced? MG 15
F TR6 Rust and small hole on floor pan- TR6 Triumph 6
H MGB MGB floor pan question MG 4
A Rocker panel or floor pan first Triumph 1
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
Healey Nut Insulating Floor Covering Austin Healey 7
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
