TR4/4A TR4A floor pan removal - easy or hard?
tdskip
In doing my research on how best to remove the TR4 floors it appears that they are best removed by drilling out the spot welds.
Does anyone have pictures of the various spot weld locations, or experience actually having done this?
Do you have a favorite spot weld removal tool?
TR6oldtimer
I did a complete floor replacement on the passenger side twice (don't ask), and have yet to do the driver's side. I reinforced the door openings and took the body off the car.
The first time I used a spot weld drill bit that has a flat face to drill out some of the welds where I was concerned about retaining the metal behind where I was drilling, for everything else I use a drill bit just a little larger then the weld. You can get a spot weld bit at good parts houses, Eastwood, or Harbor Freight.
The second time, again with the body off the frame and up on saw horses, I cut the floor out with a cut off wheel, then ground the welds off. It takes some care, but goes as fast if not faster (or was it just practice). I did use the spot weld bit in places I could not get the grinder into.
If you have an air compressor that can keep up with air tools, being smaller, they're the best in my opinion.
Oh, I did the floor first, leaving the sill and rocker in place to help support the body, which gets real flexible with the floor out.
toysrrus
Man; Better You than Me:
No punt intended:
I`ve never had the "Pleasure" & I don`t believe I would undertake such a Project: Your really looking at messing around with the "Structural Integrity" of the Car; I believe?
Best Wishes; Russ /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif
Simon TR4a
I think time-consuming rather than difficult.
I had mine done by the pro's at the bodyshop, so I may be underestimating the job!
Simon.
T
tdskip
Except for the out rocker the rest of the car is pretty solid so I was hoping (please, please, please) to keep the rest of the body intact on the frame.
Am I smoking crack in holding on to the hope that I'll actually be able to do that?
TR6oldtimer
Well, I do not know what you are smoking, but here are the facts.
If you have enough good metal around the perimeter of the old floors, you can cut out the center, then from your new floor, cut a piece big enough to over lap the hole a 1/2 inch of so, then weld it in and seal it up.
If not, then you will need to replace the entire floor. As you will note, the floor panels have a lip which fit down behind the outer rockers. Because of this, the floors can only be replaced by lifting the body.
From what I saw of the passengers side, at least on that side there does not seem to be enough metal to form a lip, so IMO a complete floor replacement is in order.
And here, the lip behind the rocker is partially gone.
Simon TR4a
I am sorry, it was part of a much larger job of painting the car.
The floor panels cost about $250 each, maybe a similar amount for labour. Cost for prepping and painting the entire car, which I disassembled and reassembled, was $5000 including sandblasting and minor dent removal (no rust as a New Mexico shell!).
Simon.
K TR4/4A TR4A Removing the old floor mount bolts? Triumph 9
J TR4/4A TR4A initiated my new garage floor Triumph 2
PeterK TR4/4A TR4A floor replacement Triumph 10
T TR4/4A TR4A front floor - patch or bolt new ones on? Triumph 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
