Well for starters, parts ain't parts, AE and standard County bearing, standard lifter, most reground camshafts, some gasket sets, some of the piston sets out there are flat out junk. I use AE 21253 pistons , APT cams, chilled iron lifters, tri metal bearing, vernier timing gear sets, new valve spring, alot of the time new valves, ARP rod bolts, Payen gasket sets ( a real biggie on A-series 1275 engines) and if you build a engine like this, which incldes new guides in the head, hardended exhaust seats, and get good machine work done, it's real easy to be at or near $2000 dollars in parts and machine work if you use the best part even if the engine is going back stock or near stock, now add a ported head to the mix, and let a professional prep everyhting put it together for you, so you don't have to pull it out a half dozens times to get it right, and yep $5K sounds about right.
