Fiquire in the SC/NC area here's run down on machining cost
Bore cylinders for oversized pistons aprox. 150.00 for 4cyl, a little more for 6 cylinder
Line bore/hone mains if needed aprox. 200.00
Deck head aprox. 50.00
Deck block aprox. 100.00
Size big end of connecting rods (big time important) aprox. 75-100
Resurface flywheel aprox.50.00
Grind and polish crankshaft aprox. 150.00 (if you anywhere near Spartanburg, SC I highly recommend Spartan Crankshaft, if near Charlotte, Carolina Machine also does a good job, aot of machine shops butcher this job, check with local racers to see where they go for crankshaft work, the number one reason crnakshaft crack is from a butchered grind job and grinder too lazy to put a good filet radius on the ends of the journal)
Install hardend exhaust seats in cylinder head aprox. 150.00
Casutic wash black and head aprox. 100.00
Then there's alway the little things you may feel more comfortable having a machine shop do for you, like if your engine has cam bearing removing and replacing them. Other things like magnfluxing internal engine parts, vlave job and head rebuilding, you want to take the high road here. Then if you are leaning towards a performance build, they is always balancing, I always get stuff zero balanced, meaning everything is done separately, anything other than that on inline motor is just laziness on the machinist's part.
Hope this helps.
