BN7 Heater switch operation
RDKeysor
Bronze
I have yet to drop the heater control on my new car to inspect the sliders and the two pull switches. This isn't addressed in the standard Healey shop manual, so here goes. What switches on the fan motor? I attempted this while driving the car home from up north, and in addition to not being able to get the fan going, I concluded that the water cutoff (its little handle being missing) was probably shut off, as well. I know I need to get a better book, but I would appreciate help with this elementary issue. No, the car didn't come with an owner's manual.
bob hughes
The central 'lever' - air temperature control - on the heater control panel slides sideways right, it also pulls out - heater boost switch - , if you pull it out, your fan motor should work, push it back in to stop it.
I would suggest that you get yourself an 'Owners Handbook' to go with the workshop manual, it should fill in all the missing details. We have one over here ( new Print) that sells for ÂŁ9.95 plus postage, not sure what that converts to in dollars, but it is not a lot of money. I have a genuine 100/6 one that I had with my first Healey ( second hand car ) and inside it is a receipt for engine oil for a 3000 dated 6 April 1966 belonging to a Sir J ? can't read the name.
Just looked into it a bit further, seams that the garage in Frizinghall was part of the Appleyard group - Applyard was the chap who used to rally the Jaguar SS 100 with his wife
:cheers:
Bob
R
RDKeysor
Bronze
I did, and it did, with a roar. Thanks for saving me a lot of probing. This was as unlikely as finding the reset for the trip recorder in my Porsche 968, a real mystery for those who don't have the owner's manual. In that case I do. Thanks.
Johnny
Even if the water valve handle is broke you should be able to tell if the valve is open or not. I believe the knob should be down in the closed position and up in the open position.
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
H BN7 and BN2 Lengths Austin Healey 3
A BN7 Front Hub Stud Nuts Austin Healey 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
B Roof vent position on BN7 hardtop. Austin Healey 15
B Cold Start Problems BN7 Austin Healey 21
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
F Which Original Oil filter assembly for BN7 Austin Healey 19
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
F BN7's left Austin Healey 9
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
Healey Nut BN7 Austin Healey 6
R BN7 Speedometer issues Austin Healey 1
T BN7 wiring diagram in color Austin Healey 7
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
rjc157 bn7 electronic choke Austin Healey 0
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
J 1960 BN7 2 seater roll bar. Austin Healey 5
R BN7/BT7 Windscreen Installation Advice Austin Healey 5
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
J Wood dash for 60 BN7 Austin Healey 16
S Green/white BN7 Chequered Flag Austin Healey 7
R How to erect at BN7 hood [top]? Austin Healey 4
bighealeysource BN7 sells for crazy money Austin Healey 22
R Proper Timing Technique '60 BN7 Austin Healey 0
Healey Nut Red bn7 Austin Healey 7
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
B BN7 with BT7 VIN on eBay Austin Healey 11
R BN7 Windscreen removal Austin Healey 7
L 3000 BN7 insulation Austin Healey 11
R BN7 Coil Wires Austin Healey 3
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
M Steering Wheel modification for a BN7 Austin Healey 15
R How to install a BN7 hood [top] Austin Healey 3
R BN7 / BJ7 Dash Top Removal Austin Healey 11
AH67 The size of battery for 62 BN7 Austin Healey 16
AH67 Spinning starter motor BN7 Austin Healey 13
AH67 exhaust & Battery kill switch- mkii bn7 Austin Healey 13
dougie 1960 BN7 For Sale Austin Healey 6
Jim_Newman Bn7 fan Austin Healey 6
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
