Spinning starter motor BN7
AH67
The starter on my BN7 has been acting up as of late. When I push the starter, the starter motor turns faster than usual and does not engage the flywheel.
Battery was installed a couple of months ago...
Is there a quick fix or do I need to change SOLENOID, starter.
Thanks all
AH67
vette
AH, If the starter is spinning the Solenoid is working. Since it sounds like the starter is not engaging the flywheel, then the bendix on the starter shaft is broken or (hopefully not) the teeth on the flywheel are gone.
TimK
it is easy to remove the starter (from underneath) -- just two bolts and some wiring to undo. Then check condition of bendix spring and whether the starter gear is stuck on the shaft. Could be freed up and greased up to function correctly. If spring is broken, replace.
FWIW, I rebuilt my starter over 100K miles ago and it's worked flawlessly ever since. I cleaned the bendix mechanism thoroughly and lubricated with a light silicone oil. I thought using any petroleum-based lubricant might attract dust and eventually gunk things up.
AH67
AH67
thank you all.. tried to work on the BN7 today and battery was drained, I thinking it could be a bad battery,, worth a try first?
TimK
Recharge the battery, that's not the problem. Dead batteries won't spin starters, but spinning starters will drain the battery
5
57_BN4
Charge the battery up on the bench then take it to a place that sells batteries and get them to put it on a load tester. If it passes, check your charging system and any lights left on or if it fails replace it.
If you don't have a battery charger, get one of the modern electronic ones that has a 'float' mode which can be left on indefinitely to maintain battery condition when not in use. CTEK make good ones.
Andy.
TimK
I cannot explain why a weak battery would spin the starter but not engage the starter gear with the flywheel. Andy's advice to get your battery checked is of course good. If you have no further problems engaging the starter gear with the flywheel, it must have been a fluke.
AH67
AH67
fair enough, I take a fluke anytime... really appreciate all the advice.. now I need to buy a battery. Everyplace I go to suggests a different group
DerekJ
When you say you 'jump' started it, do you mean from a battery installed in another car with jump leads or do you mean you push started the car? If the former then the issue could be an intermittent problem with the starter motor meaning it might need replacing or refurbishing as intermittent problems tend not to just disappear.
zeinfeld Spinning starter motor Triumph 15
Steve1970 TR6 Ok if T.O. bearing is spinning while clutch is engaged?? Triumph 5
longbridgehealey Speedometer cable not spinning Austin Healey 15
T Oil pressure when spinning motor on w/ battery Triumph 12
BIBBER CLUTCH NOT SPINNING Restoration & Tools 11
G Spinning Water Pump Triumph 4
E Spinning in circles Restoration & Tools 11
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
