G
Curious, what with my overheating problem after re-installing my radiator, what if I pull the top off my thermostat and lift out the thermostat, open the heater valve and pop the rad cap...can I slip my fan belt off and free up the water pump and spin my water pump and get some pumping action though my cooling system. I could probably get the pump to spin with some kind of drill and pulley rig. Would that work? Just to observe the flow though the rad and water pump housing (thermostat opening).
