BN7 Windscreen removal
RDKeysor
Bronze
I want to remove the BN7's windscreen so that I can drill a small hole through the bottom of the dash to install a lift-the-dot stud immediately to the right of the rear-view mirror. My car had a woodscrew threaded stud that pulled loose because of force from the tonneau fitting that attaches there. I have a new stud with a machine thread that requires a through hole for installation. Not having a very small right-angle drive drill or a say 10" long 1/8" drill that would let me drill from the bottom, I think I need to get the windscreen off so I can drill from the top. I will also take the opportunity to re-ecure that pesky rear-view mirror. There are slotted screw visible on the windscreen mounts on either side of the car secured with nuts visible under the dash. The manual says there is also a fitting pins visible on the underside. I don't see those. Ditto the bolts heads the manual says will be exposed under the door pillars with the doors open. I know something is holding the windshield frame, as loosening the two visible slotted screws with nuts doesn't free the windscreen. Help!
R
RDKeysor
Bronze
This responds to my own post regards windscreen removal. If I had thought to examine the very detailed drawings in the Moss catalog, I could have seen the answer to my own question. This was a lesson for me, and I hope it helps others. Those drawings are very detailed and a great resource. Thanks, Moss!
healeyblue
If it were me I would look into an extension for the drill bit and try and drill from the bottom. You may end up opening up a can of worms removing the windshield.
R
RDKeysor
Bronze
Thanks, Rick. This is a fantastic source. For some reason I was unable to download the file, but I have recorded the address. Anyone who hasn't examined this file and wants to know exactly where every washer, etc., goes, this is the source.
HealeyRick
I learned of the factory parts list when I was restoring my Bugeye in the late 1970s and early '80s. I was buying parts from a long time BMC dealer that allowed me to make a copy of their "Mechanical Service Parts List" and "Body Parts Service List" for Sprites. They were invaluable in restoring my Sprite and when I started the restoration of my BJ7 they were the first things I looked for. If you do a Google search, you can sometimes find a free download or, alternatively an eBay search will find a CD or an original copy.
Frankly, I don't know how you do a concours restoration without one. I've been a concours Sprite judge, and my manuals have been a final say as to what's original. Admittedly, there may have been some variance from the BMC lists to what was done in the factory, but it certainly is a great guide as to what was supposed to be correct.
R
RDKeysor
Bronze
I found the windscreen removal pretty easy, though I enlisted a friend to lift it off. One wild card was a thin metal shim that dropped out of the right side when the windscreen lifted off. It is drilled for the two bolts in the door jam, and I will return it there when I reassemble. I removed the dash top--leather in my car's case--and quickly discovered that the lift-the-dot stud supplied by a UK firm was barely long enough to penetrate the wooden underlayment below the leather top. I could only get a few threads of engagement of the nut on the 10-32-threaded stud. I decided to fiberglass under and around the attaching nut to provide a more secure installation--if you drive with the passenger side of the tonneau in place, it puts a strong tug on the stud. After the fiberglass set up, I found that the stud still had some wobble. Not wanting to have to repeat the dash/windscreen removal process in the future, i cut away the fiberglass holding the nut, removed it, and drilled and tapped a piece of 3/8" round stock, cut off a threaded slice, installed it on the stud and re-fiberglassed the area a second time. This much larger "nut" provides a very strong. wobble-free installation. If I seem less than fastidious about my work on the car, which I think is a beautiful specimen, understand that the car has a Smitty Toyota conversion done by the PO, and the original box and overdrive are enjoying retirement in my garage. It will never be a concours car. Ditto the very nicely restored vinyl-covered seats that came with the car, recently replaced, including the runners, with a pair of aftermarket leather covered seats. These are beautiful. Originality is fine, but quality and serviceability are important to me. I drive this car.
healeyblue
Currently available "tenax" studs all have the same threaded shank length. The original stud that goes on the dash for the tonneau is longer by about a 1/4 inch. I found this out too when redoing the BN4, so I had to reuse the original one at the dash.
R BN7/BT7 Windscreen Installation Advice Austin Healey 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
H BN7 and BN2 Lengths Austin Healey 3
A BN7 Front Hub Stud Nuts Austin Healey 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
B Roof vent position on BN7 hardtop. Austin Healey 15
B Cold Start Problems BN7 Austin Healey 21
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
F Which Original Oil filter assembly for BN7 Austin Healey 19
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
F BN7's left Austin Healey 9
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
Healey Nut BN7 Austin Healey 6
R BN7 Speedometer issues Austin Healey 1
T BN7 wiring diagram in color Austin Healey 7
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
rjc157 bn7 electronic choke Austin Healey 0
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
J 1960 BN7 2 seater roll bar. Austin Healey 5
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
J Wood dash for 60 BN7 Austin Healey 16
S Green/white BN7 Chequered Flag Austin Healey 7
R How to erect at BN7 hood [top]? Austin Healey 4
bighealeysource BN7 sells for crazy money Austin Healey 22
R Proper Timing Technique '60 BN7 Austin Healey 0
Healey Nut Red bn7 Austin Healey 7
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
B BN7 with BT7 VIN on eBay Austin Healey 11
L 3000 BN7 insulation Austin Healey 11
R BN7 Coil Wires Austin Healey 3
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
M Steering Wheel modification for a BN7 Austin Healey 15
R How to install a BN7 hood [top] Austin Healey 3
R BN7 / BJ7 Dash Top Removal Austin Healey 11
AH67 The size of battery for 62 BN7 Austin Healey 16
AH67 Spinning starter motor BN7 Austin Healey 13
AH67 exhaust & Battery kill switch- mkii bn7 Austin Healey 13
dougie 1960 BN7 For Sale Austin Healey 6
Jim_Newman Bn7 fan Austin Healey 6
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
R BN7 boot latch Austin Healey 16
