I'm just learning my way around this car--I last owned one in 1963--and recently discovered the headlights aren't working. The switch has no feel at all. I have been told that I can can shut off the battery and connect a jumper cable across the switch poles (I'm assuming there are two). Switching on the battery should turn on the lights, confirming that the switch is bad. Ditto I can hook up my faithful test light across the poles to determine if I have power there. Initial examination tells me that this under-dash area is going to be difficult to access. First, I need to know how to detach the pull knob on the switch. I then assume I can remove the exterior nut and push the switch through the dash, pulling it down where it can be worked on and/or replaced. Looking ahead, do any of the usual parts dealers, NAPA, PEP Boys, etc., offer the 35 and 50 amp fuses these cars require? My recently sold Jag Mark 2 used a traditional 50 amp fuse, and I believe I had to get those through a Jag parts specialist. Thanks for all of the help I have been given as a rejoin the AH fraternity as a senior citizen.
